Results 1 to 23 of 23
Thread: New To the Z
    Sep 2010
    West Babylon, New York
    1991 318i
    New To the Z
    Bought myself a 1997 1.9 5-speed manual transmission Z3 as a non-running project. Body is rust, ding free. Broken water pump impeller and driver side floor is water filled. Hopefully I can get it driving.
    Lawrenceville, GA
    4 BMWs.
    Welcome to the forum! You'll find lots of info here, and don't be afraid to ask for assistance!
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Welcome! Hopefully this was not overheated, seeing how the WP is toast.
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Sep 2010
    1991 318i
    I would be happy for any/all assistance that the forum provides. Got the water pump and belts from FCP. Hopefully I can remove the drivers seat this weekend and vacuum the floor/carpet properly.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    There’s a plastic Y pipe on the back of the head you’ll want to replace while your cooling system is apart probably lines as well. I’m sure the 4 banger guys will offer the most concise info. There was a individual coil pack mod out there to replace the stock coil pack that can fail too
    Sep 2010
    1991 318i
    Installed the water along with the belts this morning but the car would never start. Engine would only turn over very weak. Bought a compression tester at Harbor Freight, one cylinder checked in at 30psi the other three had 0psi. Maybe dead engine?
    I would drip a little oil into the cylinders to lubricate the piston rings and help them seal, then compression test again
    PRICE CUT on ALL FABRICS
    Tallahassee
    1998 Z3 M Roadster.
    Quote Originally Posted by mutty View Post
    That’s a shame.
    Purchased a 98 myself with similar issue.
    The broken water pump should have given me a clue.
    After similar repairs and testing we resigned ourselves I the fact that the cylinder head was damaged from overheating.
    Pulled the head and sure enough there were cracks between the valve ports and coolant passages.
    Replaced with a good head from a pick and pull.
    Worked perfectly after that.
    Sep 2010
    1991 318i
    Thanks for the "heads up" info. Car would do well for my 160 mile daily commute.
    Need to find a head now then?
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Bought myself a 1997 1.9 ... as a non-running project... driver side floor is water filled...
    ... Car would do well for my 160 mile daily commute. Need to find a head now then?
    You need to replace the entire cooling system or you could be into yet another head. Once you get the car running, it may not have the reliability to commute that far. Not the fault of the car, but of its history. Who has been under the dash. Alarms and sound systems. Have the electronics under the carpet been damaged. Where are the leaks. Were the windows used a lot. Was the trunk opened and closed a lot. Were the climate control knobs used a lot. I would want access to a standby commuter car.
    BMW MOA 696, BMW CCA 1405
    Sep 2010
    1991 318i
    Always had more than one car. Old faithful met an unfortunate demise so I need a replacement. Never fearful of "hoopty" as a commuter.
    Sep 2010
    1991 318i
    Bought a 318ti auto just for the engine. Going to tackle this soon. E34 m5 chrome-molly steel flywheel and a Valeo clutch/pressure plate combo. Anything I should whilst the engine is out?
    Lawrenceville, GA
    4 BMWs.
    Hate to tell you, but the 318ti would have been a better, quieter, more comfortable choice for a 160 mile daily commute. Could have simply swapped it to manual and been done with it. ;-)
    Sep 2010
    1991 318i
    318ti was wrecked in the front, clean interior though.
    Nov 2018
    orange county California
    2001 BMW z3 3.0
    These cars are fun to wrench on. Enjoy your new ride !!
    Lawrenceville, GA
    4 BMWs.
    Ahhhh
    Sep 2010
    1991 318i
    Going to part it out. The little Z3 seems to remind me of the e30 318i.Drove like a go-kart. Pure fun.
    Sep 2010
    1991 318i
    Got the clutch/pressure plate/flywheel setup and decided to do a weight check before install; 25lbs. Seems as if it is going to be a 12lb weight loss going from the stock setup to the e34 M5 setup.
    Quote Originally Posted by amancuso View Post
    Idk, maybe more comfortable because its a coupe but its a Z3 underneath... Same suspension and everything
    Lawrenceville, GA
    4 BMWs.
    Quote Originally Posted by BimmerBreaker View Post
    Yup. More space more headroom less noise.
    Sep 2010
    1991 318i
    I do not like the looks of the ti. That little Z seems more appealing. Going to do a COP conversion also using GM heat sink truck coils when it is up and running.
    Jan 2019
    Montreal, Quebec, Canada
    1996 BMW Z3
    Hey Mutty, hope your project goes well, I am looking for a rear diff for my 1.9 z3 i think both the 318 or the Z3 one would work.
    Its a small case diff 168mm let me know if you have the part or willing to sell
    thank you
    Mar 2013
    Cave Creek AZ
    98 Z3, 02 Z3MC, 07 Z4MC
    I think I smell an LS swap coming on.
  1. Welcome to the "new" Bimmerforums!
    By Black Majik in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-26-2005, 12:20 AM
  2. new computer
    By Atticka in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-04-2001, 02:32 PM
  3. New Board, and Info overload
    By C.Yang in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-03-2001, 12:06 PM
  4. New issue of Road & Track- gotta love the cover!!
    By ScottDetroit in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2001, 10:47 PM
  5. Good choice on the New board
    By Andrew 97M3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-26-2001, 11:54 AM
