RM European Auto Parts
Results 1 to 13 of 13
Thread: e46 330 trunk open indicator
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    curious to hear any suggestions/thoughts on this one.
    2003 330 - one day the trunk lid open light lit up on the dash, and wouldn't shut off regardless of the trunk position.
    i had been having some issues with the trunk open button on the trunk itself not working so this seemed like a good time to do some investigation and order some parts. the parts aren't expensive, and they aren't that difficult to change.
    having had a similar problem on both a previous bmw and a vw - i started with the trunk actuator.
    ordered a bmw part - installed it - and, no change. if i latch the trunk manually while the lid is open the lights in the trunk go out, and the indicator goes off on the dash. if i unlock the trunk, those things come back on (as expected). if i close the trunk - the trunk open light stays on on the dash. the trunk closes, latches, etc. - all works great.
    today - i tried adjusting the rubber stops on the lid but that didn't change anything. i also tried adjusting the strike itself but that didn't change anything either.
    all other monitored openings - doors, etc. seem to work just fine.
    the fact the indicator light on the dash goes out when i close the latch manually while the lid is open makes me think the wiring and GM are both fine - although, i didn't start digging into wiring yet - it just doesn't seem to make sense.
    short of black tape on the cluster or seeing if i can code out the ability to monitor the trunk lid, any thoughts? anything obvious i'm missing here?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    There is a micro switch built into the latch itself. I would say that you could open it up and adjust the micro switch, or just replace the latch itself.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    Hi Darin! that’s the baffling thing - it’s doing the same thing with a brand new bmw part.
    Mar 2003
    St. Joseph, Mo.
    if i manually latch the actuator with the lid open, the trunk lights (inside the trunk) go out, and the indicator on the dash goes out. that's what led me to believe it shouldn't be a wiring issue - but, i guess i'm at digging into the wiring at the trunk lid next....
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Hi Greg, What happens if you close the trunk and then press down hard on the lid? Light go out?
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    hi chris!!
    honestly, i didn't think to try that - i'll give it a go and report back....
    Mar 2003
    St. Joseph, Mo.
    so, finally got a chance to fiddle with this some more.
    pushing on the trunk didn't change anything.
    however, after messing with the trunk lid/body harness snorkel i was able to finally get a result. i can now make the lid indicator on the dash flicker on/off, so, definitely got an issue with a wire or wires in that bend point.
    i had suspected all along that was the most likely scenario, but, opening the lid and manually rolling the latch shut made the indicator on the dash go off - so, that was contradicting a wire theory. i didn't have time today to open the harness and fix the issue - but, will do that soon.
    dworthy's Avatar
    Nov 2010
    Like the E36, trunk wiring seems to be a problem with the E46's as well as they show their age.
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    yup, absolutely darin - and that really was my first suspicion that i had a wiring issue, but, the fact that i could get the indicator to go out by rolling the latch manually with the lid open really threw me for a bit. when i get time to open up the harness at that spot i'll see for sure and if a wire issue that'll be an easy fix at least!
    dworthy's Avatar
    Nov 2010
    I am having a similar problem with the wagon, the sprayer quit working. At first if I slammed the gate, it would work so I though it was the electronic control unit, but it is the wiring.
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    i meant to come back to this earlier - but, been busy.
    anyway - yes, after digging into the trunk lid harness where it bends and enters the body, we found a couple of damaged wires and at least one broken wire. a little wire repair later and all is happy now....
    classic issue. just kinda crazy that with the trunk open it was making enough connection on the broken wire...
    Apr 2020
    Newport RI
    2005 E46
    2005 E46 Trunk latch, the open trunk indicator light in on, I have checked fuses 49-5a ,52-30a and 60 25a. all fuses are fine. I've positioned the trunk key in 12 clock position. I just purchased a trunk latch switch from BMW same issue. My trunk lights do not work I'm curious if the Trunk latch issue and the trunk lights are part of the same problem. Any suggestions would be graciously appreciated.
    Mar 2003
    St. Joseph, Mo.
    as i did here (ideally, you would want to open a new thread for your issue), but, i would check the wiring that goes through the trunk on the passenger side. once we found one damage/broken wire, we found several. relatively straightforward fix with a soldering iron or crimp/seal connectors....
  1. E46 E46 330 Calipers and brackets
    By euroguy in forum Brake Kits, Rotors & Pads
    Last Post: 05-12-2010, 01:44 PM
  2. E46 323 Trunk won't open with key or remote
    By norwegian540 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-22-2009, 09:24 AM
  3. Trunk shut but trunk open indicator stays on
    By mimikr in forum 1999 - 2006 (E46)
    Last Post: 12-13-2007, 01:36 PM
  4. Fs E46 330 Carpet Trunk Panels
    By CAR ENTHUSIAST in forum Exterior Lighting & Body Parts
    Last Post: 06-13-2007, 08:47 PM
  5. Trunk Lid Open indicator issues
    By djc4 in forum 1996 - 2003 (E39)
    Last Post: 02-15-2007, 09:25 AM
