Recently bought a 1995 E38 730 automatic, currently there is no drive no matter what gear I put it in . No error message on the dash or anything and the shift level seems to change gear without issue.
So I'm assuming it's an a drum failure in the transmission and the transmission will require a rebuild. Could I be wrong?
Does the car use a ZF 5HP18 gearbox? I have not been under it yet to check the plate that is attached to the gearbox but everything I have seen online seem to point to this transmission.
Can a 5HP18 from from an E34 530 or E38 728 be used as a replacement?
Thanks in advance.
Anyone?
Sadly many forum users are from the US so probably can’t give you a solid knowledgeable answer regarding your Euro model. Hopefully someone from the UK could weigh in.
From what I see online you do have the 5hp18. Not sure if there are any variations depending on the engine model or not. Sorry not much help! Good luck!
You could try this...
http://the7seriesregister.co.uk/
Mike Drives:
BMW's
E24 - 635CSiA - (1) 1985 (US)
E24 - 635CSi - (1) 1985 (EC)
E31 - 850iA - (1) 1991 (Black)
E31 - 850iA - (1) 1991 (Calypso Red)
E32 - 740iA - (1) 1994
E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
E32 - 735iL - (2) 1990
E32 - 750iL - (1) 1990
E38 - 740iLA - (2) (1) 1997 & (1) 1998
E38 - 750iLA - (1) 1998
E38 - 740iA - (1) 2000 "Short Sport"
E39 - 528iA - (2) - 2000 & (1) 1997
Also:
2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
2014 Dodge Dart Rallye (Daily Driver)
2007 Mercedes Benz CL600 (Brabus SV12S)
Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
1967 Buick Riviera (2)
