Results 1 to 4 of 4
Thread: M50TU IACV specifications
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Bentley says IACV specs for M50 are 40 ohms between pins 1-3, 20 1-2, 20 2-3, same as M20 and M30, different from M60 which is 23, 12, 12, respectively. M50TU is not listed separately and it uses a different IACV. Bentley is known to be wrong about specifications sometimes. Can anyone confirm what a VANOS M50's IACV should test at?
    NW suburban Chicago
    hiss by my window
    The M50tu idle valve is same one used on M52 & M52tu & perhaps others.
    Bosch # 0 280 140 545 I have several examples of this valve carrying different BMW #s, 1 744 713 & 1 738 981
    The per Bentley published spec for the M52 valve is 20 ohms between 1&2 and 2&3, 40 ohms between 1&3
    checking the 4 known working valves I have on hand I find the 1&2 and 2&3 values average 12.6 and 11.4 respectively and the 1&3 value averages 23.2 among the ones checked. Remarkably similar to the M60 values .
    So, it would appear that once again the good folks at Bentley have it wrong. They have a staggering job of verifying and proof reading but this makes the second such discovery in three days for me. See my ABS/DSC thread in E39 section if curious about the other.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by moroza View Post
    Sifu, with all due respect, you are Sifu... We are all merely, students at your calibur. Besides you and Ross, who else can fulfill your inquiry? No disrespect to anyone but, I'm sure most agree.. I wish I could help. I'm just trying to reinstall the intake camshaft splash shield. A simple task that is a bit challenging at my pay grade..
    moroza's Avatar
    BFE
    E34T
    Quote Originally Posted by ross1 View Post
    M60 values were my result as well. I wasn't sure which was defective - my IACV or Bentley's writers. Not the first time IME either.
    Quote Originally Posted by drewusmaximus View Post
    Well, you could unplug your ECU and measure the ohms between pins 54, 2, and 29 (at the plug, not the ECU) - much easier than measuring the IACV directly - but since Ross tested four known good ones, I say no need.
  1. M50TU IACV specs
    By moroza in forum 1991 - 1999 (E36)
    Last Post: 05-11-2019, 03:02 PM
  2. Replies: 8
    Last Post: 12-19-2011, 05:45 PM
  3. Specific wheel/ tire advice..
    By guilleso in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-11-2001, 10:38 AM
  4. M3's (Specifically 95's) - Left side higher than your right?
    By Zippy M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-27-2001, 02:57 AM
  5. Replies: 5
    Last Post: 05-03-2001, 09:29 AM
