Results 1 to 9 of 9
Thread: 325is w/ S52 street/track car
    Tacoma WA
    2002tii, E30, E36, 996
    SOLD
    Hello fellow BMW enthusiasts, its time for me to pass on my E36 street/track car. I've recently bought an E30 to track as I'm more passionate about that chassis.
    1995 325is (332is) with an S52 engine, converted to be a street/HPDE car. Runs and drives well and has been very reliable for the three years I’ve owned it. I bought it with most of the performance parts installed but in neglected shape and have brought it back to be a reliable car that will track all day without issue. Its not too stiff or loud to drive around on the street, some days I drive it to work or just take it out on a cruise. I recently drove it from the Seattle Area to Grass Valley Oregon (500 miles round trip plus track miles) for a track day without issue. Lots of performance parts and recent maintenance. Estimated miles: 210,645 (see below for more info).
    $8,900, located in Seatac WA, pm for more information
    Pictures in craigslist ad because photobucket is not being very nice recently:
    https://seattle.craigslist.org/see/c...983120665.html
    Old thread of this car from the guy who built it, its an interesting bit of history:
    https://www.bimmerforums.com/forum/s...833-Fs-1995-33
    Video of the car on track:
    https://www.youtube.com/watch?v=2w6PaVsZx8o
    Engine:
    S52 3.2l M3 engine converted to OBD 1 w/ M50 manifold
    Active Autowerke chip
    Euro/540i MAF Sensor
    Bimmerworld intake boot
    Throttle body appears to be oversized
    Evosport underdrive pulleys
    JP Performance headers
    UUC RSC36 Exhaust
    Polyurethane mounts
    Aluminum oil filter housing cover
    ASC delete
    Stewart Water Pump
    S54 Radiator with aluminum shroud
    Spal Electric Fan
    Bimmerworld Silicon upper and lower radiator hoses
    AC Delete (have parts available)
    Metric Mechanic baffled Oil Pan with safety wired oil pump nut
    Dr Vanos Stage 1 vanos unit recently installed
    AFE Dry flow air filter
    Driveline:
    UUC Stage 2 8lb flywheel w/ E34 M5 clutch
    Polyurethane Transmission mounts
    3.38 LSD
    Rogue Engineering Short Shifter
    Suspension:
    TC Kline True Match SA coilovers w/ 400/500lb springs
    TC Kline Camber/Caster plates
    TC Kline Rear Shock Mounts
    Ground Control Adjustable front and rear sway bar links
    Racing Dynamics front/rear adjustable sway bars
    Polyurethane sway bar bushings
    Rear RTAB limiters
    UUC Magnesium front strut bar
    E30 M3 Aluminum Front Control Arms
    Recent alignment at Truline in Bellevue, corner weighed for 200lb driver, car weighs 2940lbs w/ half a tank of gas
    Wheels/Brakes:
    Team Dynamics 17x8 wheels w/ Pirelli all season tires
    TR Motorsports 17x8.5 wheels w/ MAXXIS RC1 tires
    Stoptech 4 Piston 332x32 ST40 brake kit
    Hard Motorsports front brake ducts
    Hawk DTC-60 track pads
    Hawk HPS 5.0 street pads
    Stainless steel brake lines
    Recent brake fluid flush with RBF660
    Interior:
    Das Sport bolt in half cage w/ harness bar
    Sparco Grid II seats
    Sparco Steering Wheel
    5 Point harnesses
    Autometer Oil Pressure and Oil Temperature Gages
    Radio/speaker delete, wiring is still there but a previous owner hacked up the wiring for the amplifier
    Exterior:
    Euro glass projector headlights w/ HIDs
    M3 / M-technic body conversion w/ 2x front bumpers, one silver, one black
    E36 LTW replica wing
    Carbon fiber hood
    Motion Motorsports Aluminum undertray
    Tow hooks
    Defects:
    Oil pressure transmitter stopped working recently, will order a new one
    Crack in corner of bumper
    Sagging headliner
    Various small paint chips and door dings
    Mileage: The original cluster with the car was losing power when I got it so I swapped in a spare. Original cluster said 205,027 on it, current cluster now says 199741. There was a long period where the mileage was never reported, so if you look at the carfax you won't see any discrepancy in the mileage and there should be no problems registering if your state requires the mileage.
    Work done within last year:
    Knock Sensors
    AFE filter
    Fuel Filter
    Oil Changes ever couple track days with Redline 10W-40
    Injectors refurbished
    Crank and Cam sensors
    Fuel Pressure regulator
    Several Vacuum Hoses
    Right rear trailing arm replaced with new bushings/ball joints
    Vanos rebuilt
    Spark Plugs
    Ignition coils (5/6 one failed and I installed an old one back in)
    Mar 2013
    Cincinnati, OH
    05 GTO
    PM sent - let me know if you don't get it, I keep getting an error so not sure if it sent
    May 2019
    Los Angeles
    F80 ZCP, Porsche Macan S
    Shoot me a text, I will be in Seattle on Wednesday and can pick car up in person - 310-919-6909
    Tacoma WA
    voodooMan - PM'd you back
    HpdeJ - texted you
    Tacoma WA
    bump
    Tacoma WA
    bump
    Tacoma WA
    bump and price drop
    Tacoma WA
    bump
    Tacoma WA
    dropped price, added some video
  1. For Sale: 1993 BMW 325is modded street/track car Houston, TX
    By turbo mike in forum Race Cars & Track Parts
    Last Post: 05-01-2008, 08:46 AM
  2. For Sale: 1993 BMW 325is modded street/track car Houston, TX
    By turbo mike in forum 3 series & Z Series
  3. Replies: 0
    Last Post: 04-28-2008, 12:12 AM
  4. Replies: 0
    Last Post: 08-15-2007, 09:52 PM
  5. 1989 BMW E30 325i White Coupe 5spd – Street & Track Car
    By GreenRacer in forum 3 series & Z Series
    Last Post: 08-15-2007, 09:46 PM
