Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 66
Thread: Never Ends
  1. #26
    May 2014
    Clemson, SC, USA
    02 530i
    Alright so got my cable in and got everything set up. I was able to read some shadow codes for engine and transmission but it won't let me connect to the ABS/DSC/Steering angle etc. I've tried all 4 positions for the switch on the cable. If I remember correctly it said it can't communicate with the module or something along those lines. Any ideas?
  2. #27
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by fuzzy530i View Post
    Solder pins 7&8 together in the cable. Then you'll be able to connect to all modules.
    Sent from my SM-G965U using Tapatalk
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  3. #28
    May 2014
    Clemson, SC, USA
    02 530i
    I thought the purpose of the cables with the switches was not having to do that? I will have to come up with a way to get it to work tomorrow, I don't have any of my soldering stuff with me currently
  4. #29
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Which INPA cable do you have ? and which switches are you alluding to ??
    As far as I know, there are cables with 1 switch that can bridge pins 7 & 8, so that you will not have to solder them.
    The problem you apparently have where you can connect to the engine and transmission modules, but no other modules in the car - that problem was related to bad "Chinese" cables with fake FTDI chip that the software driver does not recognize and actually disables.
  5. #30
    May 2014
    Clemson, SC, USA
    02 530i
    https://www.ebay.com/itm/For-BMW-INP...72.m2749.l2649
    is the one I bought. I searched and found this one out of CA instead of China like the rest that would've taken a month to get here.
  6. #31
    May 2014
    Clemson, SC, USA
    02 530i
    Even with connecting 7 & 8 it still says something about no response from unit
  7. #32
    Oct 2017
    Looks like the right cable.
    When you connect and activate INPA, do you have the icon lights on for battery and ignition ?
    Can you access and read the status of the engine and transmission modules for your car ?
    Try it with either position of the switch. You will need to turn off engine key, exit and reload INPA after switching.
  8. #33
    May 2014
    Clemson, SC, USA
    02 530i
    It will let me read the engine and trans. I didn't realize you had to restart it when switching. Mine has 4 positions in total so I will have to try them all. Ill report back
  9. #34
    May 2014
    Clemson, SC, USA
    02 530i
    Well, just had to change the switch position and restart. Read ABS and got 33 (Open left front wheel speed sensor), 88(pre-charge pump), 81(pressure sensor). Deleted and read again and 81(pressure sensor) and 97(steering angle sensor). Read the steering angle sensor codes and got 9 and 11, cleared and re read and it 9 stayed. Not sure what the SAS codes mean. I cleared a bunch of things so gonna take it to class and then tire shop to see about patching/replacing my tire that has a screw in it. When I get back I will read everything and see what is stored again.
  10. #35
    Oct 2017
    Good job, Kudos..See it ends!!
    Now you have a well functioning INPA set-up that can read and program all the modules on your car. Happy debugging.
    For a full list of error codes, check out this thread: http://www.bimmerfest.com/forums/sho...689&highlight= (posting #13 in particular)
  11. #36
    May 2014
    Clemson, SC, USA
    02 530i
    So I initially got what the codes meant from this thread by bluebee
    https://www.bimmerfest.com/forums/sh...d.php?t=558345
    Should I use the thread you linked instead? And now I just have to fix whatever is actually wrong, the brake and abs lights were off at the beginning of the drive and then came on towards the end. Not to sure about the DSC light though, it was on at the end but i didn't check at the beginning. I'll read them again when I get home.
  12. #37
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Post the code(s) your getting and the meaning.
  13. #38
    May 2014
    Clemson, SC, USA
    02 530i
    I posted what I got already in post 34. I will post the new ones once I get them read, is there an easy way for me to post pictures of what I get instead of just the numbers?
  14. #39
    JimLev's Avatar
    Sundance Mesa, NM
    Yes, from your PC it's easy. (I've never done it from a phone).
    Save pic on your hard drive then click the 4th icon from the right side above, (you have to be writing a post to see them).
    Pick from computer option, then choose file (might have to resize pic first if the file size is large), then upload it.
    Once it's uploaded you can left double click on it which will open up another window, pick large size, then OK. Your done.
  15. #40
    May 2014
    Clemson, SC, USA
    02 530i
    Not entirely sure what order it will post the pictures in but if you read the quote it should help make sense of them. Below will be the new pictures of what i read after errands. For SAS 9 is the code that won't erase, and for ABS/DSC 81 is the code that won't go away.
  16. #41
    Jan 2015
    Shreveport Louisiana
    ive never seen an 88 code to be anything but the ABS module needing repair. if it was my car id send the module in for repair, after getting it back, clear any residual codes and go from there.
  17. #42
    Oct 2017
    OK..
    Before you do anything withy the ABS, try to recalibrate the SAS (steering angle sensor) and reset the trifecta lights (ABS/DSC/Brakes).
    You can do it using the following procedure with Tool32 - from the INPA software installation. :
    (Load Tool32, Open group file DSC57.PRG, then double click "test_lenkwinkel" in the jobs list, wait 10 seconds, exit and remove key)
    See:
    https://www.bimmerfest.com/forums/sh...d.php?t=890659
    Then test drive again. I am assuming your battery is fully charge, and your alternator is in good working condition. yes ?!
  18. #43
    May 2014
    Clemson, SC, USA
    02 530i
    I will try that tomorrow once I am done for the day. And yes, i was looking at some things when i had the computer connected and car running, battery was at 13.7
    And thank you for the link and instructions, I tried searching for ways and only found a manual method of turning your wheel lock to lock then driving straight.
  19. #44
    May 2014
    Clemson, SC, USA
    02 530i
    Well it didn't work. I tried the tool32 steps and it didn't turn the lights off. So cleared all the codes and tried it again, still nothing. Oddly enough when i read the codes after that there wasn't any for ABS/DSC or SAS. So tried it again and still didn't work. Cleared codes and read them a few more times, ended up getting 97, 88, and 81. Cleared and kept reading (still nothing on SAS just ABS), got 81 and 97, cleared and re read and got 88 and 81, rinse and repeat and got 81. Guess this means it is the pressure sensor or pump?
    Edit: Well just took the car to get my sick gf some wanton soup and everything but the DSC light was off. I'm perfectly happy with that, I prefer the DSC off. I'll wait a few days and re scan the error codes and see if there are any or if the lights come on.
    Thank you for the info/help Chedley!
  20. #45
    Oct 2017
    Well, if it is only the DSC yellow light that stays on, your problem(s) are gone.
    If there is a DSC button on your dashboard, press it. Then keep scanning for error codes with INPA, if any.
    Also, make sure you have DSC57 on your car (for Tool32) which I guess you do. Check it with a search on your VIN #.
    Hey, it ends well after-all... !!
  21. #46
    May 2014
    Clemson, SC, USA
    02 530i
    Well spoke to soon. They're back, ABS codes 33, 81, and 88, and then SAS code 9. Guess I will have to do some more digging and some diagnosis to figure out exactly what it is.
    Edit: I'm not sure what has changed but since i did the "test_" thing any time I clear the codes it turns off the Brake/ABS for one drive then on the next start up they're back. Before the test when I cleared them it didn't go away.
  22. #47
    Oct 2017
    Well, that confirms that you do have a bad ABS module that needs to be fixed/rebuilt.
    You should also check and clean the brushes of your SAS -steering angle sensor-, often that is all there is to it. Then re-calibrate it ( with the
    "test_lenkwinkel" job in Tool32. )
    and test again.
  23. #48
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by Chedley View Post
    Brushes? I thought it was an optical sensor??
  24. #49
    May 2014
    Clemson, SC, USA
    02 530i
    Even though I probably won't do it for a while, what are my options for the ABS repair? I'm assuming I can buy a new one (no go), but is there anywhere that rebuilds them for cheaper or anything? Can I get one from a similar year e39/e46 from somewhere like LKQ?
    And once I take my final in a few weeks I will mess with the SAS
  25. #50
    JimLev's Avatar
    Sundance Mesa, NM
    BBA Remanufacturing in Taunton, MA or Module Masters.
    Both have websites and stores on eBay.
  1. Yikes! Never ending power steering leak
    By 318power in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2003, 07:17 PM
  2. I f'in swear the party never ends!
    By Dan in forum 1991 - 1999 (E36)
    Last Post: 12-20-2002, 10:31 AM
  3. Mod fever continues... will this never end?! Help!
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-26-2002, 06:14 AM
  4. It never ends...
    By John@BPG in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-28-2001, 05:49 PM
  5. The never-ending brake, rotors and track pads thread
    By Mike Mount in forum 1992 - 1999 M3 (E36)
    Last Post: 03-21-2001, 05:24 PM
