Results 1 to 25 of 27
Thread: Z3 Seat Issue, Not the usual.
    May 2019
    NJ
    98 M Roadster
    Hello, New member, new owner of a 98 M Roadster. I registered to ask this question as after days of searching I’ve had no luck and I’m sure I’ll have more issues in the future.
    So, I completed the passenger side seat bushings, and it went over very well. Took a break and proceeded to start the driver side. Went to remove the rear bolts and they are stuck completely. I was able to remove the front two. So I called in reinforcements. My neighbor who has every tool under the sun and actually builds dirt track cars and has twice the muscle as me was able to break free the outboard rear with tears in his eyes and a breaker bar hanging out the car a couple feet.
    NOW THE ISSUE, none of us, me, neighbor, family member, and a good friend can get the inner rear bolt out. I don’t think it’s actually seized as the other rear looked brand new. I think it’s torqued so strong I can’t get it out. I’ve tried every type of penetrating oil and numerous combinations of breaker bars and extensions. I even had someone put their foot and weight on the bolt to keep a good bite as used my leg/foot on the bar. Nothing.
    The major issue is the seat back is preventing me from using a proper impact drill as the seat back is keeping me from using it head on.
    The seat motor still works, and I have it maxed out but I still don’t have enough clearance. Is there anything I am missing? Is there a way to remove the seat from the rails with the one bolt still attached? I can deal with the sliding seat but I feel handcuffed if I ever need to get the seat out in the future.
    All my reinforcements said I’m pretty much out of luck, and one said take it to the dealer which got me thinking. What would the dealer or any other mech do in this situation?
    So any help would be appreciated as I am at a loss. Someone out there has had to deal with this before. What would you do? Thank you everyone.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Have you tried something like this with the impact drill? For me, impact tools are the best tools for removing stuck nuts.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Sounds like it might have been cross threaded, and will probably break when you get it out. But, then you'll have a LOT of access to sheared bolt you can drill out and rectify a number of ways.
    How much power behind your impact, assuming you can find an adapter that works?
    I just purchased a Nano air impact made by Onyx. I just learned they make a 90 degree version as well:
    https://www.amazon.com/Astro-Pneumat...ateway&sr=8-14
    Their standard Nano is about the most solid piece of tool I've ever held. Tolerances are incredible, and first trial made me happy.
    Also wonder if you can't get a u-joint adapter on the bolt:
    https://www.amazon.com/DEWALT-Drive-...gateway&sr=8-5
    Nathan in Denver
    May 2019
    NJ
    98 M Roadster
    Some of those ideas might work. Before I get crazy. “Crazy being cutting the rail”. So I guess there’s no “easy” way to get the back of the seat out while keeping the rails to the car. I think I’m going to look into one of those set ups. Only issue is I probably only got one or two more try’s before it’s stripped from past attempts. I don’t know how much power the impact drill has, I borrowed from a buddy. It’s just 20v deWalt. I know....
    Ive always been able to get a U joint on them, then a huge breaker bar or impact
    Aug 2015
    Denver, CO
    Quote Originally Posted by ZedsDead87 View Post
    Electric or air will let you know for sure. I've got a decent electric impact that has only ever failed to free a couple strut bolts on a friends rusty heap. It was cheap too:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    As an aside, that monster even just fits behind Z suspension with the wheel turned.
    Nathan in Denver
    Dec 2017
    Plainfield Indiana
    1999 M Roadster
    I had a similar experience, mine was stripped though. I think the PO tried to pull the seat, stripped it, and said to heck with it. I ended up carefully cutting the bolt off with a dremel tool, I did cut a thread or two but had no other choice. Good luck and once you get them out, it'll be worth it.
    Feb 2019
    PA
    2001 BMW Z3
    Consider yourself lucky that you can move the seat forward and get access to the rear bolts. In my case, I bought a vehicle that was completely rusted out under the seats and the motor did not work. Getting access to the rear bolts was virtually impossible. My goal was to try to save the seats and re-leather them. Unfortunately, despite my best efforts too disassemble the seat to get access to the bolts... it was a lost cause. Since the seats were in poor condition I ended up cutting rails and buying used seats. I agree with S8ilver, If the bolts happen to break off you can remove the seat and work on drilling/Extracting them out.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Yeah yeah, been there done that. It's "stuck". Just like the outboard one. Air tools won't help. Penetrating oil will make things worse. But I haven't been deaten, yet. 5/8" universal impact socket. Not a socket on a universal, but a socket with the ball style universal built in. 4 foot of 1/2" extension. Adapter to socket if needed. Large breaker bar. Length of pipe. Friendly neighbor. Assemble, steady, pull. CRACK.
    /.randy
    Aug 2015
    Denver, CO
    Quote Originally Posted by rf900rkw View Post
    Is that a cross between beaten and defeated? I like it.
    Nathan in Denver
    Apr 2019
    NJ
    2000 Z3 2.8 5spd
    Mine was stuck in there pretty good, I used a 1/2 ratchet with a 3/8 reducer and a 3/8 16mm socket, it was the perfect height on the rail. Maybe you can use a short or long pipe on the end for leverage.
    Feb 2009
    Charlotte, NC/Denmark
    2K Z3 2.8
    The seats will separate from the rails if you so desire. 2 bolts toward the rear and the front is held in with sort of a pac-man style piece of metal. If you can locate and remove the 2 bolts in the rear, the seat portion should slide and release. That should give you some room.
    Zed's dead baby. Zed's dead.
    Sep 2003
    kansas city
    98 Z3, 01 330i, 07 328iT
    Look at the attached photo to see the seat bottom. As previously mentioned, two bolts near the back of the seat will allow it to slide forward and potentially come off the seat rails. These two bolts appear as looking whitish in the pic due to the oxidation and are on the seat rails.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by CoconutPete View Post
    Quote Originally Posted by JRowe View Post
    Just be mindful of the wiring passing between the seat and rails...
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    impact gun has worked for me. start slow and increase intensity. sounds like it is really on there tho
    Dec 2007
    Great Dismal Swamp
    Quote Originally Posted by s8ilver View Post
    I'm at work. Sometimes (often) I get interrupted mid-thought. Mid-word, even. But mostly it's just contributions from Sir Arthur Itis. You ought to see what autocorrect does to me.
    /.randy
    Jul 2010
    Philadelphia, PA, USA
    2001 M Coupe, 2002 M3
    I had to take my passenger seat out to do the fuel pump replacement- I used my Dewalt electric impact gun- it took a little bit, but they came out without any problems. I think the hammering of the impact gun helps break loose bolts that are corroded in.
    May 2019
    NJ
    98 M Roadster
    Thank you all for some good advice and motivation. I am going to try a U Joint on the impact. Taking a few days away so I can clear my mind and frustration. I’ll be back successful or asking the best way to drill it out. Thanks
    Feb 2009
    2K Z3 2.8
    Quote Originally Posted by Randy Forbes View Post
    Yes! Don't use this technique to take the seat out of the car. I would use it to move the seat far enough up so that you can hit the bolt with whatever you need to hit it with.
    Then I would re-assemble the seat with just 1 of the bolts hand-tight. Unplug everything at the lower harness and remove the whole assembly. Then you can deal with it outside the car.
    Kent, Ohio
    1998 M Roadster
    Be sure to use a six point socket with a tight fit.
    Oct 2018
    Lawrence, Kansas
    2000 BMW Z3 2.3
    I juwt replaced my seat bushings last night.
    Same problem. Same bolt...inside driver's seat, rear bolt.
    After working at it for nearly an hour, I decided that a professional mechanic might have a better technique than an amateur do it yourselfer. And I knew that the professional mechanic would have more tools in his arsenal. It took him three minutes and cost me a $10 tip. Everybody wins.
    One surprise I experienced. All the youtube videos said that the bushings would need to be sanded to fit. To my surprise, mine fit without the sanding step. They fit perfect...nice and snug.
    Speaking of youtube videos, I found the following to be the most useful...
    https://www.youtube.com/watch?v=n6PsUywdt74
    Here's some before & after pics...
    May 2019
    NJ
    98 M Roadster
    Good to hear I wasn’t alone. I’m thinking about taking it to the mech as well but I’m going to give it just one more try. One more
    Lawrenceville, GA
    4 BMWs.
    Any update yet? What Randy (rf900rkw) said sounds like it would work best. Whereabouts in NJ are you? Burlington Twp here.
    Al.
    May 2019
    NJ
    98 M Roadster
    Ahhh no luck. Got a 20v impact on there with the u-joint but even the impact said “nope”. I’m at a point where I think I’m going to wait for it to get nasty hot out or cold and take it to my local mech as my only 2 options left are “air” impact or cutting it off. I’m where Bordentown and Hamilton meet.
    Aug 2015
    Denver, CO
    I wouldn't expect a cordless to get it. My corded electric just removed my VERY tight 46mm axle nuts. My air impact didn't budge them. My 30" breaker bar with my 215lb on the end didn't budge them. My 18" breaker with a jack under the handle didn't budge them.
    It's currently $65 on Amazon Prime:
    Nathan in Denver
  1. z3 seats fs not looking for much
    By cocosultan in forum Z3,Z4,Z8 Classifieds
    Last Post: 12-22-2014, 02:27 AM
  2. E61 Self levelling issues .. not the usual !
    By o0timbo0o in forum 2004-2010 (E60,E61)
    Last Post: 07-05-2014, 09:47 AM
  3. Odd cooling system issue (not the usual problem)
    By 02Pilot in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-02-2014, 11:16 AM
  4. Getting heated seats to work in a Z3 that did not come with them
    By scottn2retro in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-07-2003, 05:42 PM
