Results 1 to 11 of 11
Thread: Solid Engine & Trans mounts, cracking?
    Aug 2012
    Central, MD
    1995 M3
    My car is now track only. E36 M3, stock drive train.
    Considering aluminum engine and trans mounts. (Why? Cause CAE or RTD shifter.)
    Any one have mount and/or chassis cracking problems with aluminum?
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    Only chassis issues I've heard about with solids are cracked engine mounting arms. Though no context was given to me about age of the car or how long the solids were run before it happened. It was suggested that I add a closer inspection of these points to my typical inspection, nut/bolt track prep.
    I've also read that some people have had issues getting the transmission to properly align with the driveshaft/rear end and they have had to shim the mounts with washers; think someone makes an adjustable trans mount but this really is only something I have read about on the forums.
    I personally plan to run full solids although my shop did suggest running running one poly transmission mount to reduce the chance of any potential issues.
    Aug 2012
    Central, MD
    1995 M3
    Thanks. The obvious next question, is hard poly good enough to satisfy a CAE shifter yet soft enough to not cause (possible) chassis/engine-mount-arm cracking.
    Jan 2006
    Gateway To The West
    2001 BMW M3
    I found a setup I like with Vorshlag.
    Motor Mounts:
    https://vorshlag-store.com/collections/bmw-e46-bushings-driveline-mounts/products/e36-46-e92-m3-polyurethane-competition-motor-mounts-pair
    Tranny Mounts:
    https://vorshlag-store.com/collections/bmw-e46-bushings-driveline-mounts/products/e30-36-46-82-92-polyurethane-competition-transmission-mounts-95a-durometer-set
    Feff
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    The E36 front subframe is known to develop cracks where the motor mounts bolt on, and that can happen with stock rubber mounts. I can't imagine that solid mounts aren't going to exacerbate that tendency. Easy to weld in reinforcements though.
    Neil
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by NeilM View Post
    Neil
    Ya know, I MAY have already done this. lol. I need to crawl under the car and double check.
    Fort Wayne, IN
    Quote Originally Posted by aeronaut View Post
    I know just what you mean. As the original owner of a 1996 M3 I lose track of what I've meant to do vs. actually got around to doing.
    Neil
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    I don't see the point really. I'd go with delrin. Just as stiff at low frequencies (engine rocking, etc) but much less high frequency buzz.
    Aug 2012
    Central, MD
    1995 M3
    Fair point! But, I think delrin would be just as hard on the chassis & mounts as aluminum?
    Aug 2012
    Central, MD
    1995 M3
    Crap. lol.
    Looks like the subframe needs to be dropped to weld these in ?
    UPDATE: yea, per Turner directions, I see.
    Oct 2005
    Canberra, Australia
    93' Turbo 325i Coupe
    Crap. lol.
    Yep, subframe needs to be removed. Here's a video I did up on the process to weld on the reinforcements. I couldn't find anything online, so did one up myself.
    https://youtu.be/iG0QKQSD1vg
  1. E36 Bimmerworld solid engine and trans mounts
    By BMW E30 power in forum Race Cars & Track Parts
    Last Post: 06-15-2017, 11:23 PM
  2. E36 NEW E36 AKG solid engine and trans mounts
    By slammeds52 in forum Engines, Performance Parts & Software
    Last Post: 12-06-2013, 11:41 PM
  3. solid motor and trans mounts E-36
    By dwennerberg in forum Drivetrain & Transmission Parts
    Last Post: 06-19-2009, 03:26 AM
  4. FS: Brand New UUC SSK, Rasp-X, and VAC Solid Engine and Tranny Mounts
    By 05CarbonM3 in forum Engines, Performance Parts & Software
    Last Post: 02-02-2008, 10:52 AM
  5. Engine or trans mounts DIY?
    By camper1159 in forum 1988 - 1996 (E34)
    Last Post: 01-20-2008, 12:40 AM
