Results 1 to 7 of 7
Thread: Found THIS under the hood today... wtf?
    Dec 2010
    Crestview,Florida Panhndl
    E60 535i M-Sport
    Did a quick check under the hood this weekend and discovered this wire “chewed” right at the damn sensor (or whatever it is).
    Cant’t seem to find it on oem.com; what is this sensor for and what is it called? Assuming it has to do with oil.
    I’m not sure how far back I’ll have to go to replace this wiring.
    Looks like the wiring harness is factory sealed along with multiple other leads... and the sensor doesn’t seem to have enough for me to solder it back on.
    Wire appears to be chewed, but I don’t think it was.
    Not sure if soldering would change the performance of that sensor either, might be a waste of time.
    Any help, I mean ANY light that can be shed on this, would be greatly appreciated!!
    // Radar //
    2010 E60 535i N54 {sleeper}
    M-Sport, Alpine White w/Natural Brown Leather
    Coilovers, APEX Race Wheels
    Trebila-tuned motor, xHP Stage3 tranny tune,
    FBO+Meth FUN!!!
    Apr 2018
    Roma, IT
    2010 E61
    That is the oil pressure switch, 12618611273 .
    #12 on https://www.realoem.com/bmw/enUS/sho...diagId=11_3971
    Soldering or crimping isn't a problem, it's just a switch. Try opening the connector if there isn't enough left.
    NW suburban Chicago
    hiss by my window
    It is the low oil pressure sender.
    The dealer sells wire "pigtails" with the various connectors(inside the plug) to repair this. A tool is needed to release the old wire. Seems you are also missing the rubber sealing boot. http://bmwfans.info/parts-catalog/E3..._contacts_elo/
    Or, you could simply splice an entire plug sourced from a wrecker. This style plug is used in many places on many BMW (and other) cars, mostly using both of the two wire positions available.
    Send me a PM if you have trouble sourcing, I have lots of this stuff.
    Dec 2010
    E60 535i M-Sport
    Quote Originally Posted by iregj View Post
    Okay, I just pulled it off. Doesn’t look like it comes apart, but I haven’t investigated that closely yet.
    Quote Originally Posted by ross1 View Post
    Now I’m getting it... thanks.
    I need to release that “catch” on the inside of the plug-within-the-plug and back out that female connector, then solder a wire to it. Then reverse the procedure, and solder the other side to the existing wire harness.
    The light bulb came on as I was reading your reply! Didn’t realize the pin connector wasn’t a permanent part of the plug. Lol
    FBO+Meth FUN!!!
    Dec 2010
    E60 535i M-Sport
    FBO+Meth FUN!!!
    Dec 2010
    E60 535i M-Sport
    Took 40 minutes. Couldn’t be happier!
    FBO+Meth FUN!!!
    Feb 2018
    California
    05’ 525 6spd
    Must be a squirrel with a Toyota back ground. My cousin’s tundra’s wiring was chewed up as well because Toyota had used an eco friendly soybean formula on their wiring insulation which attracted rodents
  1. Did some work under the hood today.
    By wojtek86 in forum BMW Rides & Events
    Last Post: 12-06-2010, 03:51 PM
  2. Well I took a peek under my hood today
    By bstar in forum 1995 - 2001 (E38)
    Last Post: 02-05-2010, 04:59 PM
  3. WTF are these items I found under the hood?? Pic attached
    By Dunkel in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-28-2005, 08:09 PM
  4. found these under my hood... + water pump question
    By n9500 in forum 1991 - 1999 (E36)
    Last Post: 03-05-2005, 03:52 PM
  5. Found out what that clicking noise was under the hood!
    By luigierik in forum 1991 - 1999 (E36)
    Last Post: 10-05-2004, 12:27 AM
