Results 1 to 11 of 11
Thread: Pump fuel relay location - 328i
    May 2019
    Neverland
    BMW 328i '13
    Hello everyone!
    I have been lurking this forum for a couple of weeks now since I got my 2013 328i, and I decided to create my first thread today.
    I'm trying to find the fuel pump relay location, but through the BMW catalog all I could find is this control unit for fuel pump. Is this the relay for this model or am I missing something? Where else could I look up this information, please?
    Thank you everyone in advance for making this an awesome and helpful forum.
    Jan 2016
    Ca
    2001 525it
    Look up new 'tis, Put the last seven of your vin in look at group 16 repair instructions I believe it's locatoted the rear seat passenger side if it was a coupe behind the rear seat side panel wear the arm rest is
    May 2019
    Neverland
    BMW 328i '13
    Thanks!
    I'll look in the passenger rear seat seat side.
    This is the only thing I found that sounded more or less similar. It doesn't look like a standalone relay.
    https://www.newtis.info/tisv2/a/en/f...-pump/H8JJuScK
    This is the one I'm interested on:
    https://www.newtis.info/tisv2/a/en/f...relay/IKpT3rHy
    May 2019
    Neverland
    BMW 328i '13
    Replying to myself. I don't know how I missed it, but there is an EBO (Installation Location) right in the parent website of the relay.
    https://www.newtis.info/tisv2/a/en/f...relay/GNuFbxcE
    So yes, the relay seems to be in the rear passenger side, under the shoulder area.
    Thanks @jclausen ! Now I know how to find stuff
    DE, USA
    '15 435i,'10 535i,'08 X5
    If this is a US spec Bimmer (turbo, direct injection), you've probably got the EKP/EKPS (first photo) rather than a relay. The EKP controls the pump speed and is known to overheat shutting down fuel supply causing engine to stall. EKP/EKPS allows pump to operate at variable volume based on fuel demand. A relay typically runs pump at full speed all the time.
    May 2019
    Neverland
    BMW 328i '13
    You are correct. I missed the Engine classification in the wiring diagram.
    This is the one I have:
    May 2019
    Neverland
    BMW 328i '13
    Quote Originally Posted by pshovest View Post
    So I was doing this to set up an easy kill switch, and thought that by adding a switch to the Green with red wire it would work, but it did not.
    This is a 22 AWG with 0 V when car is off, and ~12V when car is on (even if ignition is off). This wire goes to the Front Electronic Module.
    I'm trying not to cut into the higher current wires (14-16 AWG) like the fuse or pump itself, but I don't know which one is the right one.
    The other 22 AWG wires from this connector (red and blue with red) are constantly around ~2V, but I am not sure what their function is.
    The picture below shows the connector pin assignments of the harness connected to the EKPS. Pin 13 is the wake-up from the Front Module I had added the switch to. For some reason, the EKPS still wakes up even with this disconnected...
    Any ideas?
    Jul 2021
    Kentucky
    2007 BMW 328i E90 N52
    Just bought a 07 328i n52 motor, replaced fuel pump because of he usual crack up top. Replaced the driver side if that matters. Started up fine initially then started to ideal rough. Husband killed the car and now it won’t start. The fuel pump doesn’t engage when we try to start it but will intermittently when we open the door. We already primed the fuel line to get air out and it’s still not starting. We unhooked battery and that didn’t work either and we checked the fuse behind the glove box and it’s fine, we are thinking it’s the relay but for the life of us we can’t find the damn thing anywhere and there is no clear answer as to where it is located. Please help! We just spent a grand on new parts and this is supposed to be my car so I can give my mom my old one because hers is a death trap.
    DE, USA
    Did it run before you performed the work? If it did then a fuel line may be disconnected inside the fuel tank. The fuel pump is on the passenger's side. If you changed the drivers side part, that was the filter/pressure regulator, not the fuel pump. Check/confirm fuel pressure. There is a schrader valve on the fuel rail under the hood. Harbor freight has a $30 fuel pressure gage that will connect.
    Sep 2021
    london
    BMW 435D XDRIVE
    Quote Originally Posted by Qqwpoid View Post
    Any ideas?
    Did you find out what it was which cable to slice for the kill switch? I am working on the same project.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Quote Originally Posted by Mrslong18 View Post
    This is in the wrong model section.
    -rb
  1. Fuel relay location.
    By tommyb2b in forum 1995 - 2001 (E38)
    Last Post: 03-02-2011, 10:30 PM
  2. fuel pump relay location?
    By whoadude in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-30-2007, 03:31 AM
  3. Fuel Pump & Relay Locations?
    By Pete Jackson in forum 1983 - 1991 (E30)
    Last Post: 02-04-2007, 11:29 AM
  4. fuel pump relay location
    By jrobie79 in forum 1983 - 1991 (E30)
    Last Post: 09-23-2006, 03:22 PM
  5. 325is fuel pump relay location
    By jabroniekilla in forum 1991 - 1999 (E36)
    Last Post: 08-05-2006, 05:27 PM
