Results 1 to 6 of 6
Thread: Any suspension suggestion for an e36 sedan 325i 1991?
    May 2019
    Madrid
    Bmw e36 sedan 325i 1991
    I finally want to change the stock suspension and was looking into fix ones since I think the coilovers may be a little to stiff. The problem is since my car is from 1991 there arent many options... Im thinking about bilstein b12 sportline, but im afraid it will lower the car too much (4,5-5/3cm), so maibe the prokit is a better option (3-3cm)? Any experiences? I never had low suspension so im afraid it could touch with the speedbums... Thanks for your answers
    Oct 2014
    Memphis, TN
    95 M3, 12 335i coupe
    Koni shocks with lowering springs rides smoother than a bilstein shock according to the internet. I had bilstein HD shocks with eibach springs and my father loved them, I wanted more spring and have since upgraded. You don't really need to worry about scraping or bottoming out until you are on coilovers and just going as low as you can.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Make sure you would not get in trouble with local law before lowering the car.
    May 2019
    Madrid
    Thanks for your answers makinM and Mless!
    Yes Coiloversbis definitely too much... If there isnt too much problem with that then I would definitely prefer the b12 sportline kit!
    I already checked and you need to get them into papers paying around 160€. The good thing about prokit is that they arent as low and the springs are black, so they dont get it!
    Oct 2003
    Seattle
    99 M3
    You most likely will need to upgrade to some later model parts to install the struts. BMW made a change 06/1992 that changes hardware.
    Sway bar mount and strut mounts come to mind. I thought Turner marketed a kit, but I cannot locate it.
    The following link outlines what the parts issue is, I do not believe anyone produces a proper 1991-1992 strut, so later parts are required for the build-up
    https://grassrootsmotorsports.com/fo.../103956/page1/
    Buy Strut Tower Reinforcement Plates from 1996+E36M3, E46M3 Convertible Rear Shock Mounts, and Z3 RSM Reinforcement Plates. Paper Body Gaskets front and rear. Front and rear ‘bump stops’ and Dust Shields.
    I also recommend Koni Sports and H&R OE Sports, the OE Sports offer minimal drop.
    Aug 2013
    Søborg, Denmark
    2001 E46 325ti Compact
    I have the B12 Sportlines on my E46 and they don’t lower so much that you can’t get over speed bumps or anything.
    They are quite “sporty” / firm which is what I wanted. If you don’t want a firm ride just go for some stock Sachs dampers and you’re good. If you want to lower the car then choose the sport version of the dampers and some Eibach or H&R springs.
  1. E36 Parting out: E36 sedan (325i)- NJ
    By oekundar in forum Interior Lighting & Body Parts
    Last Post: 12-08-2017, 07:55 AM
  2. 1995 E36 Sedan 325i Roller
    By Kart Racer in forum Whole Parts Cars
    Last Post: 08-04-2015, 07:11 PM
  3. WTB E36 325is Any Suspension that works
    By dough boi in forum BMW Parts Wanted
    Last Post: 01-20-2012, 03:52 PM
  4. E36 WTB e36 sedan 325i/m3 $5k will fly out
    By raoke in forum 3 series & Z Series
    Last Post: 11-27-2010, 02:49 PM
  5. Interest for Any Suspension Upgrades for the E36
    By AuburnGrad323is in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-19-2007, 12:12 PM
