As far as I know, new stock clutch disks for the 850i/ci/csi are no longer being manufactured anywhere are are now officially impossible to find. I have shopped the entire world online and found none.
Specs:
Parameter 280TB
Diameter 280mm
Hub profile 28x35-10N
Teeth 10
Overall thickness 9.1mm new (9.4 is too thick and will not release properly)
Minimum spec 7.5mm (worn out)
The following part numbers were used for the M70 850i and M73 850ci:
BMW # 21211223228
BMW # 21211223232
BMW # 21211223283
BMW # 21211223299 (reconditioned)
BMW # 21211223300
BMW # 21211223301
BMW # 21211223410
BMW # 21211223412
BMW # 21211223413
The following part numbers were used for the S70 850csi:
BMW # 21212227157
BMW # 21212227158
BMW # 21212227496
Back in the day, there were four aftermarket suppliers that offered disks: HAVAM, LuK, Stahlgruber, and Sachs. All but Sachs quit making them many years ago. All of the BMW OEM disks were made by Sachs. For a while after BMW discontinued them, Sachs continued to make and sell them:
SACHS # 1862442031 (original)
SACHS # 1862396031 (superceded the original)
But Sachs discontinued them entirely a few years ago and they are now impossible to find.
Until recently, I thought the only options for a clutch disk were:
1) buy a “Stage 1” clutch kit from SPEC ($899) http://www.specclutch.com/cars/BMW/850/1992/Single, Exedy (many people in these forums say Exedy has one but I was unable to find it on their site) https://www.exedyusa.com/products/sport-products/, or UUC ($1,900) http://store.uucmotorwerks.com/1989-...s-c577all.aspx . The problems with this option are that they are outrageously expensive, and also they are not anything even close to resembling stock, for those of us who are trying to keep our E31's stock. Or,
2) find a used one, but it is close to impossible to find one with any wear left. Or,
3) use a different clutch (260-265mm from a V-8 BMW, such as an E39 M5 clutch and flywheel): https://www.bimmerforums.com/forum/s...cement-options
I didn't like any of these options. A few days ago, I found a fourth option: have someone rebuild your disk. H.R. Clutches specializes in this, and they say right on their web site "Antique & Obsolete is our SPECIALTY; Foreign & Domestic". From their web site it looks like they are a quality, reputable, knowledgeable company. I contacted them and sent photos of my clutch disk and the specs. He texted me back, "What we have to determine is the thickness each piece of friction material needs to be to get to 9.1mm total thickness. Would you know that spec? My guess is 3.8mm. We should be able to get a 280mm blank piece of friction material with no rivet holes and drill it out to the rivet pattern of the disc. Does anyone have an old disc to send to us to check it out?"
Now that I got my car all torn apart, I found that my clutch disk still has plenty of wear on it so I'm going to throw it back in for the next few years. But I told the guy I would post this to the forum and was pretty sure someone would eventually contact him about it. So if you need a new clutch disk, call him up and send him your old one and see if he can rebuild it!
http://www.hrclutch.com, 877-639-7150, sales@hrclutch.com
Reviving an old thread! Has anyone tried this company. I am addressing an upper oil pan leak. Unfortunately, my flywheel has some hot spots, so I am going to try to have it resurfaced. Looking for a new clutch has been difficult and I don’t want some racing clutch in the car. I am open to any suggestions.
thanks
James
2009 M6, 2005 M3 comp 6spd slicktop, 2002 M3 convertible, 2002 530i slicktop sport package, 2001 M5, 2001 750il, 1994 850 CSI 0015, 1993 M5 3.6, 1991 850i 6spd, 1988 750il, 1988 M5, 1985 535i, 1959 502....yes it is a sickness!
just get a Spec SB011 KIT
'91 850i 6sp (mint) (sold)
Thanks guys! I am going to take the advice and get a spec stage 1 clutch the one Summit and LMP have listed for my 91 850 6spd is SB271 verses SB011. I will call them to clarify. Took the flywheel to the machine shop this morning.
get the SB011... yes, it does work on a 'regular' manual car.
https://kyclutch.com/
These guys are amazing.
Thanks Dragon 850, I am going to call them tomorrow!
I just put a new Spec SB011 in the CSi.
CSi #18 - Car & Driver Magazine 1994 actual test car
-- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
BMWCCA E31 Chapter International Clubs Liaison
North America Representative, 8er.or Board of Directors
How were the results? Why Spec over UUC?
Can you confirm the flywheels for the S70 were all single mass and the 840 were Dual Mass?
