Results 1 to 15 of 15
Thread: How did you torque the crank nut (M20) ?
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    I had my motor out and waited to torque the crank nut to 300ft-lb with the presumption that setting the car on the ground, putting it in gear would be the easiest way to lock the motor and apply a lot of torque.
    When I've had to greatly exceed my torque wrench's 150ft-lb capacity in the past I've use the (my weight) x (lever arm) technique. Access isn't quite so good in this case, even with the radiator out. Curious how you all have gone about this?
    Sep 2014
    KS
    e24e30e36e39e90
    Crank holder, breaker bar with jack handle on the end. (Google e30 crank holder. It’s also possible to fab your own.)
    Jul 2013
    CT
    edit - looks like the tool commonly sold would require that the harmonic balancer / pulley be removed to be used? https://www.fcpeuro.com/products/bmw...ol-baum-112150
    Sep 2014
    KS
    e24e30e36e39e90
    Yeah it's easy to get off, 6 bolts I think lightly torqued, then you bolt the holder to where the pulley bolts to. You may want to get different longer bolts for the holder so you don't damage the originals.
    Did you replace the crank seal?
    Jul 2013
    CT
    bummed to remove the belts but that's not a big deal. I'm going to poke around the output shaft to see if theres a good place to lock the crank there but in general it seems like a better idea not to test the clutch with 300 ft-lbs and lock it at the front.
    i replaced the everything seals
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    I purchased that big heavy duty crank holding tool from Amazon or Ebay for €40 or so, specifically for the E30/M20 engine.
    A hefty piece of metal, to say the least, weighs in at around 10-12kgs.
    I heard that crank bolt/washer need to be replaced every time they are removed, heard they were stretch type. It was €10 for both at the dealership, so i just got a new bolt and washer. I replaced the front seals as well, since i do not trust the POs last workshop (everything they did was sloppy).
    It is torqued to 410 nm or so, borrowed and equally hefty 3/4" torque wrench from a machine shop next door.
    Had to make up a very short puller tool, since the balancer/drive gears fit really snug in there.
    Joliet,IL
    87 325is 96 GMC Suburban
    Just out of curiosity...is taking that nut loose/off a requirement for working on the motor, or just if you were rebuilding the motor and taking the crank out? I am not sure how I was able to avoid this issue when I replaced my gaskets/seals
    Jul 2013
    CT
    If you want to replace front main / intermed shaft seals it needs to come off.
    Would a flat stock bar as sketched clear the front shaft/intermed seal carriers?
    Sep 2014
    KS
    e24e30e36e39e90
    I was able to torque mine down without the holder, it's a manual shift, my neighbor was sitting in the car with the brake pedal down and the car in gear. Now he has an e30 automatic, and it just wasn't working on that car, it kept rolling under the torque, so he fabbed a crank holder that we used to get his torqued down.
    I asked about the crank bolt being a stretch bolt when I did mine, and was told it is not a stretch bolt.
    The only reason I took my crank bolt out was to replace the two shaft seals.
    Quote Originally Posted by somecarguy View Post
    With the amount of torque required, I think you'll want at least three bolts going through the holder. The ones you buy have all six.
    Jul 2013
    CT
    I'll ask a neighbor over and try the brakes. Mine is manual as well.
    Joliet,IL
    I think a question worth asking is... how does the 300 foot pounds of torque on the crank nut compare to the maximum amount of torque that the engine would ever produce ? in other words is it a good idea to apply that much force to the rest of the drivetrain and the even crankshaft itself ? Maybe the holding tool is the better way to go
    Jul 2013
    CT
    This is an entirely good point that I agree with. I ended up fabricating a holder from a piece of 1 in square stock and some grade 12.9 bolts. Still agree this is an instance in which having the tool is probably the right approach. Certainly not needed to remove the crank bolt but I would’ve felt better using the tool to install it.
    Dec 2018
    Germany
    Quote Originally Posted by sienayr View Post
    Well, stretch type or not it costed me €10 for a new bolt and its thick washer buddy, i was ordering several other parts as well so it was cheap insurance.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    This is exactly what I did and the crank bolt is not 1 time use
    Oct 2013
    Austin, TX
    1981 320is, 1972 240z
    I used the crank holder tool and a 3/4" torque wrench to get the 300 ft-lb setting. The end of the crank holder was braced against the frame.
    I replaced the front crank seal when I did the timing belt recently. My car had the original crank bolt with a 27mm head instead of the newer 22mm head.
    If the engine is in the car, you'll probably need to pull the radiator to get enough clearance for the torque wrench and socket. You'll need an adapter if you don't have a 3/4" metric socket set, requiring additional clearance.
  1. How do you torque the top nuts of trans mounts?
    By zrozof in forum 1992 - 1999 M3 (E36)
    Last Post: 02-24-2006, 08:56 PM
  2. Holy shiet who torques the subframe nuts + QUESTION
    By Ferris in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-06-2005, 05:35 PM
  3. How much do I torque my lug nuts?
    By InSuboRdiNaTioN in forum 1988 - 1996 (E34)
    Last Post: 02-29-2004, 06:24 PM
  4. 524td crank in M20 motor
    By ryan86242 in forum 1983 - 1991 (E30)
    Last Post: 12-07-2003, 07:07 PM
  5. Crank nut removal
    By funkmasta in forum 1992 - 1999 M3 (E36)
    Last Post: 11-23-2003, 12:14 PM
