Hey Guys,
I have an airbag light on and my Creator scanner/INPA/PA Soft could not communicate with the SRS Module so I took out the rear console trim piece and I saw the connectors were connected to the module. I tried to pull out the black connector and the sliding piece to the connector broke off. Luckily I was able to pull up on the connector with a lot of force and not ripping any wires and my connector looks like it went through hell which means I need a new connector and a small length of wires to solder and plug into the new connector. Any ideas on the part number for the connector? I will be ordering an airbag module but I cannot find the part number for the connector on realoem. I need this because it is the only hinderence in passing inspection unless there is a bypass for the airbag light on the cluster.
You'll need to get a connector from a junk yard car. Run the controller's part number through RealOEM to see what compatible cars there are. Will help to widen the search.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
Just for anyone else who finds this, the part number is 61138364662 and 61138364666 with appropriate MQS pins or pigtails https://www.realoem.com/bmw/enUS/sho...diagId=61_2217.
