I was able to charge the car and get it to start. The car also had a transmission malfunction. I towed it to my work where I have a 4 post lift. I had to push the car up onto the lift. Checked the transmission fluid and it was very low, I added 2-3 qts. Now the car will drive. I also ordered a Foxwell 510 to help with the warning lights, check engine light, etc. What else should I do before attempting to drive the car?? THANKS.
Replace the engine oil, flush the engine coolant and replace and also replace your Brake fluid.
">'85 Mlite E30, '98 E36, 1998 528i, 5 spd manual, black on black, sold in 2012 and still going past 350Kkms, now MYSTIC Blue 2004 545i, 6 spd Steptr., Adaptive steering and Xenons, Anti dazzle mirrors. Aux+Belt-Chime+Dig speedo+iDrive discl. 2007 TCU+BT Coded+Sure BT Board
List those codes when you can
The main codes I had were the following:
P0348-Camshaft Position Sensor A Circuit High Bank 2
P152B-Wheel Speed Sensor.
The ABS, ACTIVE STEERING, TRACTION CONTROL LIGHTS WERE ALL ON .
The P0348 was a bad wiring problem(looked like a mouse ate through the wiring for the camshaft sensor), I repaired the bad spot on the sensor and the code went away.
P152B was also a bad wiring problem on the LR AND RR wheel speed sensor. I repaired the wires and NO MORE ABS, TRACTION CONTROL LIGHTS, ETC.
My next issue is with the AC, I don't think the compressor is coming on. Anyone have some advice on this problem??
