Results 1 to 5 of 5
Thread: E36 running super lean with black spark plugs?
    Jan 2018
    London
    1997 E36 323i Coupe
    Hi
    I have been working on my e36 323i project for a while...
    323i
    M50 manifold
    36lb injectors
    Sc14 supercharger running around 6-7psi
    Intercooler so - 2ish psi
    328 exhuast still with cat
    Aem wideband sensor
    And loads of suspension bits..but they make no didference.
    So i have it all bolted together and trying to tune it with romraider. I have been given a few tunes for very similar set ups. They should all run the car pretty well, maybe need abit of tweaking, but should run.
    I have put a couple different tunes on but the car still acts the same.
    I know the tune is being flashed to the ecu as i had to do a ews delete on the ecu that is in the car now as i bricked the original one.
    So problem im having is...
    Everytime i start the engine it will idle for okay for a second, then drop down to 20-22 afr and run extremely lean. Misfiring and lumpy. I turn it off as i dont want to run it that lomg like that so i havent hot it to temperature yet.
    I have taken the spark plugs out twice now (in the space of maybe 10-15 starts) and they are covered in black.
    So my car is running super lean but spark plugs are black?
    I have check for vacuum leaks a million times with smoke, propane and takig every hose off and examining. (Still not saying its defo not a leak)
    But has anyone else got any more ideas of what it couod be?
    Jan 2018
    London
    1997 E36 323i Coupe
    Just a little video to show you my set up ��
    Jul 2004
    Houston, TX
    36 Cylinders
    It's most likely the tune and how it matches to your injectors and mass air flow sensor.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2018
    London
    1997 E36 323i Coupe
    Think ive sussed the problem. The map i had was running it so rich that it was missfiring. Sending unburnt air from the engine down the exhuast. Causing the wideband sensore to rean super lean.
    Jan 2018
    London
    1997 E36 323i Coupe
    I havent sussed it still having major lean readings. Its not the map. Anyone got any other ideas?
  1. FS Spark Plugs BMW M3 E36 1995 BOSCH SUPER NEW - SOLD
    By Pellogt in forum Car Audio & Electronics
    Last Post: 11-05-2013, 03:35 PM
  2. E36 WTB: E36 105/140 Amp Alternator, 6 spark plugs and 6 coil packs
    By Knicks in forum BMW Parts Wanted
    Last Post: 07-06-2011, 12:31 PM
  3. Replies: 43
    Last Post: 01-31-2011, 06:35 AM
  4. Replies: 12
    Last Post: 01-02-2010, 12:46 PM
  5. spark plugs white as snow.. running lean?
    By SupaBimma in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2005, 12:26 AM
