Results 1 to 5 of 5
Thread: 2015 335xi issues
    Aug 2016
    Upstate NY
    Honda S2000, VW Jetta TD
    2015 335xi issues
    Brought my 2015 335xi stick in because I've been hearing a new muffled whine on start up. To me it sounded like an alternator for some reason.
    I also thought I might be hearing things ( I'm a child of the 60s).
    Anyway the dealer diagnosed a failing Alternator and weeping seals on the rear diff.
    Both will be fixed no charge under CPO and I'm not crazy, that's the good news.
    Of concern is that the car only has 40k miles.
    ( BTW - Keeler BMW, Latham NY has really stepped up)
    BMW's are not Honda's. They require ongoing maintenance, even at lower mileages.
    Jul 2004
    Houston, TX
    36 Cylinders
    I have found that modern Hondas require maintenance just as much. It's just that they're a lot more forgiving when it is deferred.
    On the topic of alternators.... alternator whine seems to be a common finding with these variable charging systems. I wonder if it's something actually broken, or simply a bit noisy.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2016
    Upstate NY
    Dealer said they tested the alternator after they also heard the "whine"
    Don't know what the new Alt would cost out of pocket without CPO.
    I'm sure not inexpensive
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Not that it helps any, but BMW doesn't make alternators, and what you heard might have just been the decoupler pulley on the front of the alternator.
    The weeping differential could have been left alone, but......
    If you're the second owner, you really have no idea if the first owner abused the vehicle, but you have a warranty, at least for now.
  1. 2010 335xi Cold Start Issue...help!
    By Matt09i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-16-2014, 08:06 AM
  2. 2008 335xi HPFP issue
    By thedco in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-24-2013, 04:41 PM
  3. Need help with 2008 BMW 335XI low beam issue
    By The Koz in forum Lighting sponsored by BAVToys
    Last Post: 02-22-2013, 12:50 PM
  4. Help getting out of lease...335xi with issues
    By formgen in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-02-2010, 08:41 AM
  5. 2008 335xi radio issue
    By nauticabri in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-23-2008, 10:51 PM
