Hey, i have 94 525td. Yesterday my rear view mirror fell off, so i had to take the mirror plug out because i didnt had any glue to stick it back. After plugging in the plug my remote doesnt lock or unlock. The central locking works with key in doors, red led blinking but nothing happens. I tried resync method when you have to hold unlock and press lock 3 times, but nothing helps. Any ideas? 🙁
Does the mirror work, and would it be possible the connector is not installed right? Maybe this might help:
https://www.bimmerforums.com/forum/s...20dim%20mirror
Mirror didnt worked before, but the remote was working fine, until i took the plug out, bud i didnt messed with wiring or anything the plug fits the same way.
Tried unpluging confort box under the seat, tried leaving car without battery, nothing helps
Your problem is very simple... the key lost it's programming.. you will need to re-initialize the key. this is how you do it:-
E34 525i Touring 1995, M52B28 LSD... fully restored.
Tried that several times. When it says to press lock or unlock button after holding it when it flashes, nothing happens :/
