Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: whelp.... now fuel pump is dying
  1. #26
    Jan 2019
    Evansville,IN
    87 BMW 325i Convertible
    just ordered a spectra premium tank and pump.... wasnt that bad of a price. Apparently the spectra premium tank is getting decent reviews... i hope the pump/carrier is the same.
    1987 BMW 325i Convertible
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
  2. #27
    Jan 2019
    Evansville,IN
    i just ended up ordering a spectra premium tank and pump from amazon. Getting a new giubo and csb since i bet those havent been ever changed out from rockauto and I have to drop the driveshaft anyways. started pb blaster on the exhaust nuts.
    Looking for a diy for replacing tank, but havent found one yet.
    Jeremy Clarkson
  3. #28
    Joliet,IL
    87 325is 96 GMC Suburban
    One piece of advice might be to use the existing pump to pump the remaining fuel out of the tanks before you start removing them. Disconnecting the supply hose somewhere and connecting 12volts to the pump somehow might save you some headache depending how much fuel is in there now
  4. #29
    Jan 2019
    Evansville,IN
    The tank is empty. It had a drain plug and i got almost all of it out that way.
    Jeremy Clarkson
  5. #30
    Jan 2019
    Evansville,IN
    i got the new tank in with new pump finally! it took a week to remove everything to get to the tank. I have some parts for the driveshaft coming in to finish putting together. I was able to start it up. (without the exhaust, that was freaking loud in my garage). But I am happy that everything went in. One hole on the spectra premium tank was off, but easily fixed.Now to figure out how to get rid of the old tank. Omfg, that thing had even more rust than i originally thought. Once i got it out in the sun, it was a wonder that the tank was even in one piece. Want a major pita, but looks like it was a wise move.
    Jeremy Clarkson
  6. #31
    Joliet,IL
    Thank you for following up, I have a super eta that will surely need a tank/lines/etc , since it has been sitting in the rust belt it’s entire life. I think I have used spectra parts before on my trucks and I have never had any issues
  7. #32
    Jan 2019
    Evansville,IN
    i ended up replacing all the hoses connected to the tank also. there was rust coating the insides... as far as i can tell everything past the filter is fine. I kept the connecting s pipe since they are around 200+. (why?) i soaked it in antirust and painted the outside. I sprayed wd40 on the inside and let it set before installing.
    Jeremy Clarkson
  1. Almost sure my fuel pump is dying/dead, Just need confirmation
    By Plagueoc in forum 1992 - 1999 M3 (E36)
    Last Post: 07-31-2008, 08:44 AM
  2. HELP my Fuel pumps are dying!
    By m3dna in forum 1992 - 1999 M3 (E36)
    Last Post: 07-25-2006, 09:43 AM
  3. Anyone had a Fuel Pump die before 150k miles?
    By EEEEeeee36 in forum 1991 - 1999 (E36)
    Last Post: 04-30-2006, 11:54 PM
  4. Fuel pump died
    By Kilomph in forum 1983 - 1991 (E30)
    Last Post: 02-12-2005, 03:50 AM
  5. fuel pump about to die?
    By bugkiller in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-11-2004, 10:21 PM
