BMW of Bloomfield
Results 1 to 2 of 2
Thread: E32 750iL 1992 218,000 miles with Wokke chips, top end rebuild
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    For lots of pics, see my CL ad please:
    https://greenbay.craigslist.org/cto/...874240696.html
    I have a 1992 750iL in pretty good shape for its age and has had a ton of work done. 218,000 miles with a top end rebuild (head gaskets on up), transmission valve body rebuild and suspension work that includes Moosehead Spherical bushings. New brakes at all corners. Fluids are good. Most issues are small like sticking switches or glove box shocks and some rust spots, mainly on the front doors. AC is wicked cold, had a proper 134a conversion using ester oil (do not use PAG oil in this system). She has sat for over a year but was my daily before getting my current ride. Had it all over the Midwest on long trips without issue and I would do so again without hesitation!
    Features:
    * Wokke performance chips (new these are $500/set). Includes trans chip. Original chips included in sale. This chips remove limiter and really get this heavy car moving fast.
    * Heated steering wheel from an E38! Probably the best upgrade I have ever done on a car! Buttons on wheel do not work - cruise needs a special module installed. Radio buttons have a module in place, needs to be reprogramed, then they will work.
    * New Alpine head unit with bluetooth and all new cabin speakers (excluding the old twin 12" Type-R subs). All RCA ran with dedicated sub RCAs. Two older Alpine amps in truck in the hidden oxygen bay.
    New:
    Alternator (Duralast)
    Both fuel pumps & filters
    Radiator & hoses
    2 rebuild MAF sensors
    Rear shock accumulators
    Ignition coils (Bosch)
    O2 sensors (Bosch)
    Distributors & rotors (OEM)
    OEM ignition wires with pick-up donuts
    Crank and cam sensors
    Entine temp sensors (all three)
    And much, much more.
    Needs:
    * Deck lid (trunk lid) painted, has bad clear coat failure.
    * SRS reset, light is flashing. Probably from when I powered it up with the cluster out (doh!).
    * ABS wheel sensor. When starting to move, ABS light kicks on with ATC light. Could be a wheel sensor or more likely the toothed gear needed cleaning. Pulled sensors and cleaned but it made no difference.
    * Carpet cleaning, could use one.
    * Headliner is sagging, of course.
    * Telescoping steering is grinding - common issue, but a pain to replace.
    * Front bumper. Hit a chunk of ice so a part is missing (see pic). I have some of the parts in a box.
    * Might need battery soon because its from 2013, but its been holding a charge fine.
    Includes:
    3 almost new tires (identical to those installed)
    Extra oil filters & a couple belts
    Extra front suspension parts
    One rear LAD shock
    2 used MAF sensors
    Misc small parts
    ______________________________
    1992 750iL
    Mar 2013
    Green Bay, WI
    sold!
    1992 750iL
  1. Which one is fuel pump relay on e32 750iL 1992 ?
    By krtica in forum 1988 - 1994 (E32)
    Last Post: 11-19-2022, 05:24 AM
  2. M10B18 w/ <120,000 miles and freshly rebuilt top end! - No Longer Available
    By LazerSquid in forum Engines, Performance Parts & Software
    Last Post: 04-08-2016, 08:01 PM
  3. E32 1991 750il auto 124,000 miles
    By Mis4MOPAR in forum 7 series
    Last Post: 04-23-2013, 10:32 PM
  4. E38 1999 750il with 79,000 miles
    By shersbmw750il in forum 7 series
    Last Post: 01-07-2011, 10:11 PM
  5. Replies: 0
    Last Post: 02-12-2010, 08:38 AM
