Results 1 to 18 of 18
Thread: 55-75 mph steering wheel shake, e36 M3 1999
    McKean township Pennsylva
    1999 M3 , 1999 328is
    My steering wheel shakes between 55 and 75 mph and I'm at a loss of what else to check. I've replaced the lower control arm rear bushings. Unfortunately that didn't solve the vibration, it did make the steering feel sharper though.
    I've tried three different sets of tires and wheels on the car including a set that has been road force ballanced with no change in shake.
    The tie rods feel nice and tight, there may be a bit of radial play in the rack gear in the steering but I'd be surprised if that causes it.
    Any suggestions on what else to check?
    Current fleet:
    1999 BMW e36 M3
    1999 BMW e36 328is with rotary valve engine head
    1999 Oldsmobile Eighty Eight
    1990 Jeep Comanche Eliminator
    1962 Austin Healey Sprite
    Jun 2010
    NY
    1997 328i
    Check the front ball joints on the control arm. Raise the front end off the ground and have one person work the wheel by hand and another carefully watch the ball joints for movement. You may have to run the engine to pressurize the rack to prevent it from moving.
    Apr 2015
    Tennessee
    1998 BMW 328i
    The steering wheel lock should stop the rack from moving. For what it's worth, i also have some "shake" in my wheel at higher speeds. All my front suspension is new except for the rack and the steering column. Im going to rebuild the rack and column. Ill let you know how it feels after
    Jun 2010
    NY
    1997 328i
    Quote Originally Posted by XnWarden View Post
    Not on mine, you can try for yourself.
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Does the shaking come and go. If it comes and goes, pull over when it starts to shake and check for a 'hot' wheel. You may have a sticking brake, either caliper or collapsed flex hose.
    Quote Originally Posted by Eric93se View Post
    I'll have to try the pressurized rack, I've tried this already with the engine off. The control arms are original, I'll see what I can see at that joint.
    Quote Originally Posted by marvinstockman View Post
    I actually did have two stuck calipers, both fronts and rebuilt them both a couple weeks ago as the pistons were both rusted. It didn't change the shake. I'll check again to see if I have a hot wheel as I could have a bad hose too, they are all original at 135k miles. The shaking does not come an go it also doesn't change with steering angle.
    Current fleet:
    1999 BMW e36 M3
    Mar 2019
    Brasil
    328iA 1997
    I had this problem, can be many things, but in my case it was the shock absorber, an item that usually does not relate to this symptom and always goes unnoticed.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Most common issue causing steering wheel vibrations would be as you noted the wheels/tires out of balance. Does it vibrate when you brake (warped rotor/stuck caliper), when you turn (tie rods) or going in a straight line (ball joints)? At your mileage it’s possible to have a failing wheel bearing but I’m going with Eric’s guess and assuming the LCAs/ball joints need refreshed.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to M3 forum
    Jun 2005
    suburb of Cleveland Ohio
    99 M3
    I've had this happen twice with my 99 M3.
    Both times the cause was this - sticking caliper. I don't do the work on my car any more, too old, I have a BMW mechanic do it.
    Both times were rebuilt calipers which my mechanic strongly advised against because he said this happens and he doesn't trust them. He was right. I couldn't afford to replace with new at the time...
    Mar 2014
    Sammamish, WA
    1998 M3/4/5
    I had some pretty badly warped rotors that caused some freeway wheel shake too.
    1998 Titanium/Dove M3/4/5
    2020 Toyota 4Runner
    FL
    are slow.
    Have had a similar shake at ~80mph, and it was the front rotors.
    -Dr. Seuss
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Seems this pops up every other week....these cars are just so sensitive to everything....I've replaced EVERYTHING except for the steering rack and the lower steering assembly....I'm in the middle of it right now and hopefully, it will eliminate this for good.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Aug 2011
    WA
    '97 BMW M3/2/5
    If you've scoured your suspension and wheel components, maybe take a look to see if the clock spring in the wheel itself has play. Mine has a bit of play that shows up at around 65 mph.
    Feel free to ask about my car:
    TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
    M50 Manifold | ASC Delete | Dinan BBTB | Fan Delete | Power Pulleys | Dinan CAI |
    S54 Oil Cooler
    Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | AKG Chassis Mount Shifter
    SS Long Tubes | SS Race Exhaust |
    LTW Replica Wing | MM Underpanel | CF Sunroof Delete
    OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation | Turtle Labs Door Panels
    And Really Old Paint
    Check out my YouTube channel for more DIY's and videos about my E36 M3
    May 2010
    Brooklyn, NY
    2010 335i; 1998 M3/4/5
    As mentioned the usual culprits are the wheels, tires, or brakes. I'd suggest a bent wheel, which can still be balanced, but you say you've changed sets with no difference. If the calipers aren't sticking, and the rotors are fresh with no pad deposits, your options are:
    Tie Rods (inner and outer)
    Control arm ball joints (inner and outer)
    FACBs (you replaced)
    Shock Mounts
    Wheel bearings
    Rack
    Column
    Shocks
    Springs and perches
    Feb 2002
    Orlando, FL
    I just posted in another steering wheel shimmy thread....it was my rack, and of course, the last thing I replaced. It was one of the only original parts remaining on my 97 M3
    Mar 2012
    1995 Mugello M3 Coupe
    I'd check the front shocks. You might be able to witness it while having someone else drive next to you at freeway speeds and look for excessive movement in the wheel.
    Thanks for the replies everyone, I'm still chasing this down. The spring and shocks are less than a year old, previous owner installed some nice beilstine and eibach parts. The more I look at it the more I think it's the rack. I recently had it aligned to factory spec, it was very far out in most all measurements, and that didn't change the wobble at all. The only thing it did was make the steering lighter.
    Current fleet:
    1999 BMW e36 M3
  1. E36 For sale 3 spoke mtech steering wheel for e36 m3
    By tblah22 in forum Interior Lighting & Body Parts
    Last Post: 07-18-2013, 07:26 PM
  2. E36 Steering Wheel / Airbag e36 M3
    By Boplaw in forum Interior Lighting & Body Parts
    Last Post: 02-07-2013, 04:32 PM
  3. WTB: 3-Spoke Steering Wheel for E36 M3
    By edboc in forum BMW Parts Wanted
    Last Post: 10-28-2002, 12:01 PM
  4. Momo steering wheels for e36 M3
    By kapolani in forum 1992 - 1999 M3 (E36)
    Last Post: 07-03-2002, 02:52 PM
  5. 2000 E46 coupe steering wheel in E36 M3??
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 06-01-2001, 12:27 PM
