I bought a 2014 x1. Tool kit in trunk is missing tools. What tools should be in the tool kit?
These days not much. Did you look for it some times it can be hidden in strange areas. Check your owners manual
you can see it in the ETK, use your VIN, for example I selected a 2014 BMW X1 28i E84 SAV USA N20 , under equipment you see car tools, set of lifting jack, mobility system, warning triangle/first aid kit/-cushion
http://bmwfans.info/parts-catalog/E8...uipment_parts/
Tool bag
Towing hinge
Screwdriver
Find it, location is mentioned in owners manual
Yep, I have the tool bag, with towing hinge and screwdriver. A pretty anemic "tool kit". I added a flat blade screwdriver, pliers, and a crescent wrench.
This is more like in my 1988 E32, even including the NLA blue cleaning cloth https://www.bimmerforums.com/forum/s...6#post26184606
You know the BMW screwdriver is both a flathead and a phillips? Pull out the metal rod and flip it to the other side.
