Results 1 to 6 of 6
Thread: gt1 scanner
    Apr 2019
    sedro woolley wa usa
    99 bmw 328i
    gt1 scanner
    Hi, hopefully im posting in the right spot. i'm wondering if its difficult to use the gt1 scanner and computer software. from my understanding when i replace my throttle body i will need to reset it? just wondering if this is something i can do myself. i have a 99 bmw 328i by the way. Thanks
    Jul 2004
    Houston, TX
    36 Cylinders
    You do not need to reset any throttle settings when you replace it. I assume this is an E46 with the m52tub28 engine.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2019
    99 bmw 328i
    yes its the e46 with the m52. well that would be awesome if I don't have to. I've read online that after you replace the throttle that you have to reset the learning adaption or something, and that his requires hooking up to a computer. even in my Haynes manual it mentions this, it says with the m54 engine you can possibly try the 10 second ignition thing and that may reset it but with the m52 you have to hook up diagnostics. thank you very much
    Jul 2004
    Houston, TX
    36 Cylinders
    Also, you can just use the simpler to set up INPA with k+dcan cable (+20-pin adapter if you want), if you really need to read codes and reset anything
    -Abel
    Apr 2019
    99 bmw 328i
    What is the simpler and INPA?
    Jul 2004
    Houston, TX
    36 Cylinders
    https://www.bimmerforums.com/forum/s...xperimentation
    Most everything you need is in post 1.
    -Abel
  1. 2 questions for GT1 scanner
    By omaradas in forum Diagnostic Software
    Last Post: 08-04-2013, 08:16 PM
  2. Scanner with GT1, Carsoft, Ediabas, DIS, INPA support?
    By saleengt in forum Diagnostic Software
    Last Post: 11-04-2010, 07:04 AM
  3. Code Scanner Recommendations - Cannot Afford GT1
    By texas540i in forum 1996 - 2003 (E39)
    Last Post: 08-30-2010, 09:19 PM
  4. Replies: 10
    Last Post: 09-10-2009, 12:32 PM
  5. GT1 Scanner or Equivalent in the Bay Area?
    By phillipk in forum California sponsored by Avus Autosport
    Last Post: 08-26-2009, 04:17 PM
