Results 1 to 2 of 2
Thread: E32 750iL - Wisconsin - sold
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    Link to CL ad for pics:
    https://greenbay.craigslist.org/cto/...874240696.html
    I have a 1992 750iL in pretty good shape for its age and has had a ton of work done. 218,000 miles with a top end rebuild (head gaskets on up), transmission valve body rebuild and suspension work that includes Moosehead Spherical bushings. New brakes at all corners. Fluids are good. Most issues are small like sticking switches or glove box shocks and some rust spots, mainly on the front doors. AC is wicked cold, had a proper 134a conversion using ester oil (do not use PAG oil in this system). She has sat for over a year but was my daily before getting my current ride. Had it all over the Midwest on long trips without issue and I would do so again without hesitation!
    Features:
    * Wokke performance chips (new these are $500/set). Includes trans chip. Original chips included in sale. This chips remove limited and really get this heavy car moving fast.
    * Heated steering wheel from an E38! Probably the best upgrade I have ever done on a car! Buttons on wheel do not work - cruise needs a special module installed. Radio buttons have a module in place, needs to be reprogramed, then they will work.
    * New Alpine head unit with bluetooth and all new cabin speakers (excluding the old twin 12" Type-R subs). All RCA ran with dedicated sub RCAs. Two older Alpine amps in truck in the hidden oxygen bay.
    New:
    Alternator (Duralast)
    Both fuel pumps & filters
    Radiator & hoses
    2 rebuild MAF sensors
    Rear shock accumulators
    Ignition coils (Bosch)
    O2 sensors (Bosch)
    Distributors & rotors (OEM)
    OEM ignition wires with pick-up donuts
    Crank and cam sensors
    Entine temp sensors (all three)
    And much, much more.
    Needs:
    * Deck lid (trunk lid) painted, has bad clear coat failure.
    * SRS reset, light is flashing. Probably from when I powered it up with the cluster out (doh!).
    * ABS wheel sensor. When starting to move, ABS light kicks on with ATC light. Could be a wheel sensor or more likely the toothed gear needed cleaning. Pulled sensors and cleaned but it made no difference.
    * Carpet cleaning, could use one.
    * Headliner is sagging, of course.
    * Telescoping steering is grinding - common issue, but a pain to replace.
    * Front bumper. Hit a chunk of ice so a part is missing (see pic). I have some of the parts in a box.
    * Might need battery soon because its from 2013, but its been holding a charge fine.
    Includes:
    3 almost new tires (identical to those installed)
    Extra oil filters & a couple belts
    Extra front suspension parts
    One rear LAD shock
    2 used MAF sensors
    Misc small parts
    ______________________________
    1992 750iL
    Mar 2013
    Green Bay, WI
    sold!
    1992 750iL
  1. Replies: 0
    Last Post: 05-17-2016, 07:41 PM
  2. The finest E32 750iL is being sold once again
    By SergeBMW in forum 1988 - 1994 (E32)
    Last Post: 08-09-2015, 08:23 AM
  3. E32 1990 e32 750il $1500 whole car or parts drives great
    By e35m5csl in forum Whole Parts Cars
    Last Post: 12-27-2010, 10:35 PM
  4. E32 feeler: my grey market e32 750il
    By AHenry014 in forum 7 series
    Last Post: 09-28-2010, 01:34 AM
  5. E32 1990 e32 750il $1499 drives great
    By e35m5csl in forum 7 series
    Last Post: 09-17-2010, 09:16 AM
