Results 1 to 7 of 7
Thread: 2007 550i smoke after long idle, need advice
    Nov 2016
    Glendale AZ
    1998 540i
    I just picked up a 2007 550i, 129k miles. Overall the car seems to be well maintained. It drives great, runs super strong, doesn’t leak and doesn’t smoke when driving. This morning I was stuck in a drive through for a bit and noticed I got a plume of smoke out of the exhaust after I had been sitting for a handful of minutes. I pulled off, and it went away. I don’t get any smoke at all on start up, nor while driving normal or wide open. There are no check engine lights, warnings and no stored codes.
    The previous owner recently replaced the CCV hose assembly that comes off the valve covers and into the intake. He also replaced the ccv pressure valves (the rubber diaphragms and springs on the valve covers)
    One thing I noticed is that there is oil in that ccv line. When I opened up the caps on the ccv pressure valves and looked under the rubber diaphragm there is oil where the spring is, which leads me to believe it’s reasonable that oil is getting into the intake. Could this cause my issue? Are there other parts of the ccv I should check?
    I’ve put a couple hundred miles on the car since I bought it and the only time I see smoke is when I’ve been sitting stationary for more than a few minutes. Any advice or direction on what to check would be immensely appreciated.
    Mar 2008
    MA
    '03 330i6, '08 E92 M3
    That sounds like valve stem seals to me. Condolences.
    Jan 2016
    Ca
    2001 525it
    Check pcv valves and change the oil to the 10w60 m oil
    The valve stem seals are leaking. There may be ways to prolong the engine, and push off the repair, it's not going to magically fix itself.
    Jan 2016
    Ca
    2001 525it
    True but we have had good luck with the 10w60 oil
    Sep 2009
    Fort Mill sc.
    850i,530,x3
    I've always thought valve seal leaks, smoke on start up and WOT.
    Jan 2016
    Ca
    2001 525it
    So you either have some body replace the valve seals, expensive or try the thinker oil. Plus oil is probably in the catalytic converter so after changing the oil to the 10w 60, it could still take a while for the smoke to calm down
  1. Changed oil and oil filter and car shakes rough idle need advice
    By Romavictor7 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-10-2014, 01:04 PM
  2. Heat in cabin after long idle
    By matlock328 in forum 1991 - 1999 (E36)
    Last Post: 07-09-2013, 06:27 AM
  3. Help - Misfiring and Rough Idle. Need Advice
    By NYCM32003 in forum 2001 - 2006 M3 (E46)
    Last Post: 02-19-2010, 07:35 AM
  4. 2001 325i stalls after long idle (when hot)
    By bmwarty in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-25-2004, 11:31 AM
  5. Overheat after long idle...
    By Mark85 in forum 1991 - 1999 (E36)
    Last Post: 11-30-2003, 07:20 PM
