Hi Guy's,
Hoping to find some answers for the following problems:
1. Reverse camera not working but in it's place the navigation map comes up , the PDC is functioning.
2. Bluetooth does not seem to be working (My phone doesn't detect anything)
3. Voice control doesn't hear me, but I can hear the beep and it tell me it doesn't understand me.
4. The auxiliary port (3.5mm jack) in the armrest doesn't seem to work although its available in the entertainment hub.
I have replaced the media module in the trunk as it showed water damage, but that didn't seem to change anything.
Could it be another module that controls all or some of these features.
The radio and CD work as does Nav,
Ive run a scan with Carly and these are the results:
Instrument cluster / Kombiinstrument
Fault Code: 00A554
Fault Explanation: :ALIVE error Phone / live phone
Car Communication Computer CCC
Fault Code: 00E18F
Fault Explanation: :Central Registry does not match the target
configuration (Error Registry New).
Fault Code: 00E18D
Fault Explanation: :Awakening device has three times
unsuccessfully, the network tries to awaken (Error WakeUp Failed) /
Awakening device has unsuccessfully tried to wake the network times.
3 (Error WakeUp Failed).
Junction Box Passenger / Beifahrer
Fault Code: 00A737
Fault Explanation: :K-CAN MESSAGE (ID2BF, VALVE): FAILURE BY
TIMEOUT
I'm not experienced enough to come to any sort of diagnoses hoping someone here can.
Regards Chuck
