Originally Posted by
R.Thomas
Impressive numbers. Would running stock CR with E85 help up top too or just low range?
This is a flex car so 9:1 is about as high as we want to go.
If you were full e85, 10:1, you’d probably make 730-740 all else the same.
But this car just needs bigger injectors and about 28psi.
1989 535i - sold
1999 M3 Tiag/Dove - sold
