Results 1 to 10 of 10
Thread: a/c not working in 2003 m3
    Apr 2019
    Canada
    E46 m3
    Hi,
    The ac in my 03 m3 isn't working. I had it recharged last year and was working fine. Since summer is coming soon, my ac started to act strange. First, it would blow cold for about 10mins of driving, the hot air started to come from the vent. It will blow cold when I made a right turn then hot air when it's going straight. I pulled the code with inpa and got the following. I got the code aux water pump short circuit to ground. Anybody have any advice on what to do?
    25 Zusatzwasserpumpe
    Error frequency : 23
    Kurzschluss gegen Masse Fehler momentan vorhanden
    Errorcode: 19 42 17 30 4B B7 98 11 03 76
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    The "25" means an aux waterpump, but I haven't seen one on a E-46.
    Did you use a store style "Recharge"?
    So what I would do is see about getting the system evacuated, tested, leak dye added, and charged at a HVAC shop.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Apr 2019
    Canada
    E46 m3
    The ac was recharged by a professional. Ok I will do that and see. Thanks
    dworthy's Avatar
    Nov 2010
    QUOTE=JCF076]Hey,
    You responded to my 281c and 281d post. I have another issue now with the 27ad BSD generator code popping out. [quote/]
    So what I would do is remove the large red wire, and check the post and eye for burnt marks, ect. When the nut gets loose, it can arc and drop the code.
    Darin
    Current:
    Past:
    M-Flight Member
    Apr 2019
    Canada
    E46 m3
    Thanks dworthy, I'll take a look on the weekend
    May 2019
    jordan, ny
    1998 740il, 2011 F250 6.
    For the air conditioning sounds like the compressor is kicking on and off. Would consider visually checking the wires to start. If it blows cold air there is still a charge. If you can get it to stop while standing still you can use INPA to actuate the clutch helping isolate the HVAC controls. Could just need a new compressor- if you do that have all the o-rings replaced so it doesn’t slowly leak anymore
    Apr 2019
    Canada
    E46 m3
    Finally got some time off work and replaced the aux water pump and hcv... the ac blew cold for a day and now the ac blows cool and warm air again. I used inpa to check the value, the pressure sensor is at 5.7 bar which is very low, and the set value shows -27.5... anybody can advice would be great.
    dworthy's Avatar
    Nov 2010
    Can you get a high and low pressure reading from the service ports?
    Normally you should be looking at 200-250 psi on the high side, and about 30-45 on the low. It will cycle thru as the compressor kicks on of course.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2009
    Fl
    1998 M3 Coupe
    I had a similar problem on my 2003 M3. I rebuilt the heater control valve (below the MAF) and the ac worked perfectly after that. The heater control valve was so corroded it was stuck open. $30 dollars and 30 mins of my time fixed the issue.
    - Steve
    -'98 M3 Coupe
    -'03 M3 Coupe
    -'83 911 Coupe
    -'05 911 Coupe
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Good catch...it wasn't the AC...the heater can overpower the AC
    Quote Originally Posted by merlinfe View Post
    - Steve
    But interestingly it can only do it when the engine is hot. The diagnosis is that the AC works when the engine is first started but goes away when the engine warms up.
    And BTW, I hate to say how may dang heater control valves I've replaced on Saabs since 1984 (sold my last one in 2008, 87 900T with about 340hp...). Chevy's etc....most of the time it's coolant issues causing corrosion but its often just darn poor designs that don't hold up to underhood heat.
  1. Replies: 0
    Last Post: 04-24-2013, 04:18 PM
  2. Lighter plug not working on E36 M3
    By swtyphoon in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-29-2009, 12:42 AM
  3. Climate control not working properly (99 m3)
    By hpirs4n in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-30-2006, 06:54 PM
  4. Seat heater not working :help: '98 M3
    By Chris1091 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-15-2004, 06:53 PM
  5. Cigerette lighter port not working on 95 M3
    By Chongus in forum 1992 - 1999 M3 (E36)
    Last Post: 12-28-2002, 10:51 PM
