Results 1 to 8 of 8
Thread: KEY FOB #1 works; KEY FOB #2 does not work
    Apr 2019
    Richland, WA
    2002 BMW 330CI Convt
    I have a 2002 330ci convertible. I bought a key off Amazon and programmed the FOB (and it locks and unlocks the doors) but it won't start the car. So, I bought a key from BMW ($230) and it will start the car, but the FOB will not work. The dealership says that the receiver in the mirror is bad. WTHeck? How come the $25 generic key fob works and the dealership won't. Doesn't seem logical that the receiver is the problem. New rearview mirror is $900 order from Germany only.
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Did you add/program the dealer key? When I got my dealer key, I had the car with me and they added it for me.
    Apr 2019
    Richland, WA
    Quote Originally Posted by All2kool View Post
    The BMW ($230) key fob has never been able to lock or unlock the doors. My dealership has to order them from California (after you prove ownership) and they supposably come ready to go. It does start the car. The dealership says that the receiver in the rear view mirror has a very weak signal. I don't understand how that can be the problem when the generic ($25) key fob works just fine. Walk up to the car, several feet away, push the button and the doors unlock. But, here's a catch, once you use the BMW key it voids the generic key and it will no longer work until it's reprogrammed. Otherwise, I'd just have two keys with me.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    You still need to code the dealer key with the car for the central locking to work.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Mar 2016
    Portland, OR
    Quote Originally Posted by GLOldright View Post
    They do come ready to go for starting the car but still need to be programmed for lock functions. Keep in mind - only 10 keys can be programmed. If your car has already had 10 keys programmed at any time, you will need to use an application like PA Soft to remove previously coded keys as I have been told before.
    I think the dealer is blowing you off. Obviously, the receiver is working just fine.
    That seems wonky. You really need to see how many previously coded keys are stored.
    Apr 2019
    Richland, WA
    So, if I ask the dealership to remove all previously coded keys, can we just start over and program the generic and BMW key? Or will removing previously coded keys, if it includes current keys, mess things up?
    Mar 2016
    Portland, OR
    That is precisely what I would do. I would go to the dealer with the two keys you have and request that all currently coded keys be removed and then have the two keys you have be added. Your goal here is to have just the two keys you possess be coded to your car.
    Apr 2019
    Richland, WA
    I appreciate everybody's responses. I had the car at the dealership to program their BMW key. That's when they discovered that the mirror receiver wasn't working properly. I picked up the car today. No working FOB and cannot open the fuel door. And of course, their fail-safe manual lever in the trunk does not work. Won't be driving much (half a tank left) until this is resolved, which hopefully will be soon.
    I ordered a rear view mirror from a wrecking yard today. Specifically for a convertible. $175. Once I get the mirror still have to install it and have the key programmed. Wish me luck.
  1. Key fob does not work
    By christofult in forum 1988 - 1994 (E32)
    Last Post: 08-17-2018, 09:28 PM
  2. New Key FOB but now key does not work
    By bettsbuy in forum 1999 - 2006 (E46)
    Last Post: 07-30-2016, 10:13 PM
  3. Key does not work
    By bode61 in forum 1999 - 2006 (E46)
    Last Post: 05-12-2008, 02:52 PM
  4. HELP! LOCKED KEYS IN TRUNK. ACTUATOR does not work
    By eurotunerwerks in forum 1996 - 2003 (E39)
    Last Post: 04-18-2007, 05:36 PM
  5. Key window rollup does not work from Pass side??
    By Scho in forum 1992 - 1999 M3 (E36)
    Last Post: 07-21-2004, 11:58 AM
