What inner and outer combo tie rod is everyone using with an eBay adapter and 4mm spacers?
I know these kits are not the best but the budget is tight at the moment.
Car has stock LCAs stock knuckles.
I use my own version of those eBay adapters, geometry is basically identical. I use stock inners and outers - however - you need to cut ~5/8” off the inner’s thread length and you have to cut off the taper and split from the outer, ditch the taper sleeve as well, and just use the nut as a plain old jam nut.
