Results 1 to 2 of 2
Thread: E46 Angle Adapters
    Feb 2018
    Minneapolis, MN
    2003 325i
    E46 Angle Adapters
    What inner and outer combo tie rod is everyone using with an eBay adapter and 4mm spacers?
    I know these kits are not the best but the budget is tight at the moment.
    Car has stock LCAs stock knuckles.
    Mar 2011
    PNW
    LS E46
    I use my own version of those eBay adapters, geometry is basically identical. I use stock inners and outers - however - you need to cut ~5/8” off the inner’s thread length and you have to cut off the taper and split from the outer, ditch the taper sleeve as well, and just use the nut as a plain old jam nut.
  1. E46 steering angle adapter install!! Ebay/Amazon HELP PLEASE
    By JacobPetersE46 in forum 1999 - 2006 (E46)
    Last Post: 01-01-2019, 10:07 AM
  2. E46 Angle Eye installation
    By m3gina in forum Lighting sponsored by BAVToys
    Last Post: 12-16-2009, 08:04 PM
  3. Do wide angle adapters provide decent results?
    By Hugo in forum Photography & Multi Media
    Last Post: 08-05-2009, 02:03 AM
  4. Opinion on E36/E46 wheel adapters for E39?
    By supark in forum 1996 - 2003 (E39)
    Last Post: 07-16-2008, 05:44 PM
  5. FS: e46 Aux adapter and BMW Ipod adapter
    By BJO in forum Car Audio & Electronics
    Last Post: 05-07-2007, 05:14 PM
