Results 1 to 11 of 11
Thread: e34 head stud install
    Apr 2019
    canby, OR
    1990 bmw 535i
    ive got an m30 sitting in an e34 and was wondering if anyone knew if installing them would cause clearance issuses against the firewall when trying to remove the head?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E34 forum from 5 series general
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    Not sure I understand what you are asking.
    You have a e34 535i, so it has the m30b35. What are you adding to it?
    Andy
    Dec 2004
    CT, USA
    e28, e34, e39
    You can access all of the head bolts while the engine is in the car.
    demet
    Apr 2019
    canby, OR
    1990 bmw 535i
    i want to put head studs in it but if i try and take off the head with the headstuds instaled will the head hit the firewall?
    Dec 2004
    CT, USA
    e28, e34, e39
    Quote Originally Posted by bimmer@15 View Post
    That I have not tried. It may be an issue.
    demet
    Albuquerque, NM
    way too many
    That's a very good question. You could double-nut the studs such that they behave as bolts, and drop the rear studs into the head on the bench before placing it on the block. Then drive the studs into the block, remove the jamb nuts, and continue. Same thing in reverse to remove the head.
    ​"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
    TheStigg (aka "gale")
    92 735i 5-spd, turbo pending
    89 535i 5-spd (may she rest in pieces)
    94 325ic 5-spd
    87 325is
    Dec 2004
    CT, USA
    e28, e34, e39
    Nice solution.
    So how would you lock the rocker shafts in place with studs? They will not likely move with studs, but they could move and that would be bad news.
    demet
    Apr 2019
    canby, OR
    1990 bmw 535i
    wouldnt turning them into bolts would would kind of defeat the purpose? besides you need a socket on it because if the 12 point nut. do arp head studs have special thread on the nut side?
    Albuquerque, NM
    way too many
    That was just a temporary step for unthreading the studs from the block before lifting the head off so you don't have to lift the head up the full length of the studs, which will most likely have interference issues at the firewall per your original concern. You're right, ARP head studs have a funky 12-sided flange nut which would make it difficult. The studs have a 5mm hex socket on the tips. Ordinarily they are only loosely threaded into the block. If whoever installed them used Loctite, you would likely need to double-nut them to remove them. I believe the head end of the studs are conventional M12x1.5 threads, so you could get a pair of regular hex nuts to double-nut them if need to remove the studs.
    94 325ic 5-spd
    87 325is
    Apr 2019
    canby, OR
    1990 bmw 535i
    sounds like a plan! thank you guys for your help
  1. Installing ARP Head Studs
    By RascalKing in forum Forced Induction
    Last Post: 11-24-2014, 03:08 AM
  2. EARLY E34 head unit install
    By Shuasha in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-14-2009, 09:50 PM
  3. Installing head studs...
    By ///M3///M5 in forum Forced Induction
    Last Post: 05-02-2007, 02:44 PM
  4. M30 Head Stud install ?
    By Cereal Killa in forum 1988 - 1996 (E34)
    Last Post: 03-03-2007, 04:24 PM
  5. HG and Head Stud Install Question
    Last Post: 04-12-2006, 02:17 PM
