Results 1 to 9 of 9
Thread: Crankcase ventilation for boost
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Thought I’d have a go at asking here. Have a E34 540i manual running 14psi of boost with a vortech b3.
    At a trackday last Saturday unfortunately oil started leaking out the discharge pipe to atmosphere from the catch can.
    I was looking at perhaps running a vent direct from each cam cover then running a vaccum pump to keep the crankcase back in vaccum rather than positive pressure. There is not a huge amount of info about this on the net. From the limited info about it most seem 14-16” of vaccum will also be beneficial to power generation and help minimise “blow by”.
    Anyone else had experience with this. Is an electric pump sufficient or do I need a mechanical belt driven one.
    Thanks in advance
    BMW’s
    90 E34 M5
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
    A house
    '86 325e, '14 VW EPA
    I don't know about an electric pump but my engine is drysumped and I have the vacuum control valve set to 7psi. I can tell you that with 3 stages of scavenging, at 900whp the vacuum was dropping. I've since changed from 1.2" spur scavenge stages to 1.5" roots. I don't know what kind of electric pump you'd need to be able to do the same. But you also need to address a way to separate the oil you will be sucking out. There will be a bunch suspended in the crank case that will condense after you draw it out but there is also a bunch of it being flung around so unless you have a good baffling system, the oil will be getting spat out of your suction port into your pump. Drysump pumps are meant to scavenge oil and also draw vacuum so the oil is then deaerated.
    Aug 2003
    Dallas, TX
    Z3M, X5M
    I had the same issue the last time I was at the track. I recently changed the catch can to a sealed one that could connect to the intake tube pre-supercharger for vacuum. Hopefully this would help when I have the car running again.
    -Phil
    Dec 2005
    E24, E34 x2, E36
    The only problem with connecting to the intake is I run a blow through MAF. It would get coated in oil film.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
    Aug 2003
    Dallas, TX
    Z3M, X5M
    You might be able to use a secondary-air-pump. They should pull about 4 in. some drag racers use vacuum pumps that run off the accessory belt. not sure how well they work for street application.
    -Phil
    Mar 2011
    Neverland
    E34 525i
    Quote Originally Posted by Z-Thrizzle View Post
    i have been planing on using a SAP in this manner, my car was manual swapped so im thinking of wiring it to trigger from the kickdown switch for both longevity and cause its loud.
    Dec 2005
    E24, E34 x2, E36
    The electric pump triggered via a low boost pressure switch seems like the go. Thanks for everyone’s help on this subject. Next question so what pump is the best and where do I get it from.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
    Chicago
    '99 M3
    I'm about to put in one of these Cobra pumps. Hopefully it works. There is all sorts of stuff on the net about these units.
    https://www.m5board.com/vbulletin/e3...rger-m5-2.html
    TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Those Cobra pumps look pretty cool. Only $80 on ebay.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  1. M20 boosted crankcase ventilation?
    By E34DIYer in forum Forced Induction
    Last Post: 01-08-2015, 11:06 PM
  2. crankcase ventilation hose
    By 95 325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-24-2003, 11:34 AM
  3. F/I crankcase ventilation.
    By Keith97m in forum Forced Induction
    Last Post: 04-30-2003, 04:45 PM
  4. crankcase ventilation question
    By owen in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2003, 07:18 AM
  5. Crankcase Ventilation valve?
    By Cheuk in Seoul in forum Forced Induction
    Last Post: 11-17-2002, 07:03 PM
