Results 1 to 9 of 9
Thread: Removing inner tie rod from rack
    Jul 2012
    Batavia, Ohio
    1988 BMW 325ic
    I've looked up how this comes off. That thin washer that bends over to lock it in place, looks easy enough to bend the bottom part straight so it can be unthreaded, but how easy is it to reach the portion on the top that is folded over?
    Also I don't have a thin wrench to loosen it from the rack, just plan to use a money wrench. Anyone think obtaining a thin wrench is worth it?
    Also consider that I don't have access to a lift. Will be doing this on jacks with jack stands.
    Thanks.
    Jan 2019
    Evansville,IN
    87 BMW 325i Convertible
    i spent like 10-15 at amazon for a tool to do this. I didnt even bother straightening out the washer. The tool allowed me to just twist it off. I was not reusing the tie rod though.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    1987 BMW 325i Convertible
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I just used a pipe wrench to remove mine, though I did intend the washers with a flat screw driver and finishing hammer
    No e30s again.
    Sep 2014
    KS
    e24e30e36e39e90
    Quote Originally Posted by doctorx69 View Post
    +1 these work great, you may be able to find one locally at a parts store.
    Joliet,IL
    87 325is 96 GMC Suburban
    I used a small punch and a hammer to straighten the washers and then a big pair of channel locks or a pipe wrench to remove the inner tie rod end itself
    May 2014
    Central NJ
    85325e,97318i,87vlv240
    +1 on this one, the tool does its job well.
    Sep 2014
    KS
    e24e30e36e39e90
    I will add, the other benefit to using that tool is that you can use your torque wrench to put the new one on. The torque spec is pretty low if I recall correctly.
    Oct 2003
    Seattle
    99 M3
    An old school bicycle headset wrench in 32 mm works for Tie Rods and the Fan Clutch Nut.
    https://www.amazon.com/Unior-30mm-He...-12&th=1&psc=1
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    I used a standard 32mm open wrench, the PO had the rack resealed and the shop that did the work actually punched that tab that goes into the rack internally. Meaning, that tab is forced locked. Took me an hour on either side, to gently try to pry it out.
    Now that i am reading this, i completely forgot to bend the new lock rings, just replaced them. Hope nothing unbolts till next week, will not be doing any aggressive driving anyways.
  1. Inner tie rod or steering rack?
    By Found94 in forum 1991 - 1999 (E36)
    Last Post: 06-04-2012, 07:32 PM
  2. E9x Also E8x 1-series complete power steering rack and pinion (w/inner tie rods)
    By Aamir bt in forum Suspensions, Springs & Shocks
    Last Post: 03-07-2012, 11:06 PM
  3. Inner Tie-Rods or Play in Steering Rack
    By quail in forum 1991 - 1999 (E36)
    Last Post: 12-14-2011, 11:49 AM
  4. Inner Tie Rod Removal?
    By Oxide36 in forum 1991 - 1999 (E36)
    Last Post: 04-16-2010, 05:17 AM
  5. inner tie rod removal
    By robmpulse in forum 1983 - 1991 (E30)
    Last Post: 02-06-2007, 09:41 PM
