Results 1 to 8 of 8
Thread: M70 oil filter housing
    Mar 2014
    san antonio texas
    1989 bmw 750il
    I removed my oil filter housing to make room to remove my exaust manifolds. A one way valve came out and Im not sure which way it goes back in. Does the plunger side face the housing or the engine?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    see my website, http://twrite.org/shogunnew/topmenu.html systems>>>>oil filter cannister, there are pics, had the same problem years ago, luckily I had a spare engine and could check there
    Mar 2014
    san antonio texas
    1989 bmw 750il
    Winner winner chicken dinner. Thanks Shogun
    Tucson, AZ (usa)
    91 750, 99 740i
    I have a question, what is the part number for the oil filter housing that has the cooling system ports, or is it possible to use an aftermarket replacement?
    Jan 2005
    Japan
    you mean with the separate engine oil cooler under the radiator like this? https://www.realoem.com/bmw/enUS/sho...diagId=17_0067
    on my 11/88 in hot climate version this one is installed https://www.realoem.com/bmw/enUS/sho...diagId=11_0552
    Oil filter with oil cooler connection up to 09/1989 11421715733, if there is no oil cooler, the connection have plug 17221723676
    West Coast
    two 3's one 5 three 7's
    Any idea why the oil cooler was not an option after 1989?
    Did the engineers calculate that it wasn’t necessary after all?
    I was going to retrofit my 1994 750iL with the oil cooler, but then decided to sell it after all because it really doesn’t get that hot where I live.
    Jan 2005
    Japan
    The oil reservoir looks different https://www.realoem.com/bmw/enUS/sho...diagId=11_4613
    If I remember right, there is still an oil cooler connection but that is just a kind of piping similar to the Pentosin cooling http://bmwfans.info/parts-catalog/E3...g_oil_pipes_3/
    maybe someone can check it on an 750 after 1989
    I also read that some newer E32 750 in Germany do not have this engine cooling, maybe it was just necessary for hot climate versions
    Tucson, AZ (usa)
    91 750, 99 740i
    Thanks Shogun, that is exactly what I was looking for
  1. Replies: 9
    Last Post: 05-04-2003, 02:35 AM
  2. VAC Oil filter housing
    By badmonkey in forum 1992 - 1999 M3 (E36)
    Last Post: 04-20-2003, 01:01 PM
  3. Oil filter housing
    By bungy42 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-12-2002, 08:15 AM
  4. What size socket for oil filter housing?
    By bobbO in forum 1991 - 1999 (E36)
    Last Post: 11-12-2001, 08:46 PM
  5. Oil Filter housing problem
    By vapor in forum 1991 - 1999 (E36)
    Last Post: 09-27-2001, 12:13 PM
