Results 1 to 7 of 7
Thread: Front end shakes often when going over bumps...
    Mar 2018
    Bella Vista, Ar
    2001 BMW 740iL
    seems to be often the worst when going over bumps slow, but it happens sometimes at speed as well. There is a sound, but mostly you just feel it. Not really a rattle, more an intense vibration lasting about 1 second.. I've searched google but nothing seems to fit exactly. The front sway being loose might explain it, feels right, but looking for any more input so I can check everything at once. So what ya got?
    2001 740iL "Silver Beauty"
    1986 Porsche 951 "Silver Bullet"
    1987 Porsche 944 NA Auto (rebuilding for my son's first car)
    https://home.doonze.net/filepage.php <- BMW/Porsche doc's and files, work in progress
    Houston
    2001 740il
    Ball joints
    VA
    E63AMG/Z31/Tacoma/F31
    I would agree, most likely ball joints and/or sway bar end links. If on a budget, try the sway bar end links first as they are cheapest and easiest. The thrust arms are the next most common wear item. I would suggest doing the front upper/lower arms and end links if you want to knock it all out at once. I just did all 8 front/rear arms and spindle ball joints in my wife's E53 X5 4.6is this weekend and the difference is amazing. All ball joints but one were pretty bad and although you couldn't tell with a grab the wheel and shake test in addition to passing inspection, they were all loose with play and very little grease.
    Dec 2012
    Pittsburgh PA
    87' E30 - 97' E38
    i just had this in my 97 740il. i changed the control arms. there are 2 per side and it took care of my issue. they have bushings and ball joints on them and once those are toast the e38's weight dont play around.
    good news is there are alot of options and this isnt too much of a fix if this is whats wrong.
    VA
    FCP Euro is the best place to order from imo and I use Lemforder parts as they are of good quality with equally good pricing.
    Mar 2018
    Bella Vista, Ar
    2001 BMW 740iL
    Thanks for the feedback guys, this is on the list, but not at the top yet. Just fishing for ideas right now. This car has about 10 other issues that need addressed first. So many gremlins, so little time!! I will post back with my findings when the time comes so as to help the next guy.
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    I have been doing my front end systematically. I jacked it up and wiggled the wheel found the tie bar ball joints bad. The PO had just done the tie rod ends. That got rid of the shimmy. Then I had a clunk over speed bumps that got pretty bad. I just replaced the forward control arms. Less noise now but still clunking when I brake. I have been driving it the whole time including going to the track. Take your time replace what you can Identify as bad. It is more of an OCD thing than a real problem. Like painting the Golden gate bridge when you are done you can just start over.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
  1. front end shake when hitting a bump?
    By goondock in forum 1975 - 1983 (E21)
    Last Post: 10-26-2006, 01:25 AM
  2. slight front end shake when hitting a bump
    By goondock in forum 1983 - 1991 (E30)
    Last Post: 10-25-2006, 06:17 PM
  3. Front end shake, losing my mind!! HELP!! REWARD!
    By gtp e38 in forum 1995 - 2001 (E38)
    Last Post: 11-10-2003, 09:54 PM
  4. Front end shake
    By timlangford in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-13-2003, 09:45 PM
  5. Front end shake above 60mph!
    By pinter75 in forum 1991 - 1999 (E36)
    Last Post: 12-23-2002, 01:25 PM
