Results 1 to 17 of 17
Thread: Inpa ihf-0009: No response from control unit ???
    Oct 2015
    Washington, IL
    2003 540i6
    I was doing a compression test today and when I got everything hooked back up, the car won't start. The fuel pump isn't turning on, so I'm assuming the DME is having issues. I tried to connect to INPA, but I'm getting the error IHF-0009: No response from control unit.
    Do I need to re-align the DME? I was able to get to the Activate button in the EWS menu, but clicking Activate did nothing. I'm not sure if I'm doing it right though. I've done it before, but I can't remember how.
    Please help!
    2003 540i/6
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Most likely, you have electric connectivity issues.
    With key in position 2, INPA must connect (you'd see the two buttons : battery and ignition highlighted) before you can attempt anything.
    Assuming the INPA cable is good -you did use it to connect before--
    Oct 2015
    Washington, IL
    2003 540i6
    I used the cable successfully right before doing the compression test. I am able to access other modules through INPA, but I cannot access the DME.
    2003 540i/6
    Oct 2015
    Washington, IL
    2003 540i6
    I'm going to charge the battery. We we're cranking a lot screwing around with the compression tester.
    2003 540i/6
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Dumb question but did you reinstall the fuel pump fuse? I’ve had a few moments like that where I got no start after a compression test because of leaving that fuse out.
    1995 525i 5-speed - Thread
    Oct 2015
    Washington, IL
    2003 540i6
    Haha, not the first time, but then I remembered and put the fuse back.
    2003 540i/6
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    Check the DME Ground wires.. On the 6 cyl, they (3 or 4 wires) are bolted to the chassis right below where all the wires enter the DME box in the engine. I assume the 8 cyl is the same. This area isnt' too far from where you were doing the compression test - at least on 4 of the cylinders.
    I had this problem and it was the DME ground wires.
    Oct 2015
    Washington, IL
    2003 540i6
    I'll check that when I get home. Thanks.
    More info:
    We were using the threaded adapter as well as the bung attachment for the compression tester. When I was holding the gauge in place, the green ground wire on cyl 7 was resting against my hand and I could feel pulses/shocks. When I moved my hand, the braided wire was loosely on the stud and it sparked. The braided wire did this on the other bank too.
    I also checked the fuses for the DME this morning, and they all looked good.
    2003 540i/6
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    Yeah -- some compression test instructions say to pull the relay to kill the spark too, in addition to the fuel pump. I assume the spark was because you still had some coils and plugs connected. I wouldn't think that the bad ground would cause this problem. Probably low/dead battery. Seems strange that so many people here are having these problems. (Never happened to me and I've had dead batteries often enough.) Glad GG gave us that thorough explanation.
    Oct 2015
    Washington, IL
    2003 540i6
    It looked like such a straight forward job, I didn't even bother to look for instructions. Definitely should have though. I took the DME apart and with the help of GG, he noticed that one of the ICs was burnt up.
    Here's a pic of what the IC normally looks like. (it's the one with the 25 sticker on it)
    Here's mine
    2003 540i/6
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Bummer. If that's bad there are probably other connected parts that are bad too.
    Time to get another DME.
    Dec 2004
    CT, USA
    e28, e34, e39
    Looks like one of your caps is swollen also?
    So what is the correct process for performing a compression test? Remove both main and fuel pump relays and jump the starter?
    demet
    Oct 2015
    Washington, IL
    2003 540i6
    New DME is in the mail now. I'm going to try to get through all 147 wires going to the DME to see if anything is shorted out. I think while I'm in there, I might re-route my wires like you did to yours, Jim.
    Quote Originally Posted by demetk View Post
    Yeah, I saw that cap when I was taking pictures. As far as procedure goes. If I were to do it again, I'd either look for a proper write-up (TIS or forum post) or I'd disconnect the coil connector on the dme, and tighten the braided ground down to the valve cover, rather than leave it loose. -I'd most likely look at how to do it properly though.
    2003 540i/6
    Jan 2015
    Shreveport Louisiana
    ive just left the coils unplugged, relieved pressure on the fuel rail, pulled the fp relay and held the throttle body open in doing compression tests previously with no harm.
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by waters17 View Post
    Good plan. I'm sure I have more pics than what I posted when I did it.
    You'll need to lengthen some of the wires.
    The pass side wires that come out of the front side of the wire box for the starter and oil level sensor were moved to the rear of the box. That allows both boxes to be individually removed.
    Nov 2016
    Charlotte, NC
    It would be interesting if the new unit helped with your original rough running problem. Hope so.
    Oct 2015
    Washington, IL
    2003 540i6
    Quote Originally Posted by R Shaffner View Post
    It's doubtful. The unit I burned out was actually a replacement that I got a year ago. The previous dme had corrosion issues due to coolant wicking.
    2003 540i/6
  1. COAPI 2020, no response from control unit
    By acspecialists in forum Diagnostic Software
    Last Post: 04-03-2019, 02:26 PM
  2. INPA Error IFH-0009 NO RESPONSE FROM CONTROLUNIT.....
    By Drexellake in forum Diagnostic Software
    Last Post: 12-10-2018, 05:16 PM
  3. INPA "Control Units" list for specific models
    By DaIceMan in forum Diagnostic Software
    Last Post: 12-05-2018, 03:12 PM
  4. Cant connect to all control units in INPA with my 97 M3
    By sedwilkins in forum Diagnostic Software
    Last Post: 11-03-2013, 08:50 PM
  5. HELP! IFH 0009 No Response From Control Unit.
    By forzam in forum Diagnostic Software
    Last Post: 09-18-2013, 03:27 PM
