Hi to all, Happy Eastern. Getting ready to change the oil on my manual transmission , and also the rear differential fluid.
Which fluid do you guys recommend, for each case? My 328i 2011 has 76K miles. Thanks in advance.
I'm planning the same task. Thought I would check here first.
Let's see what the recommendations are.
See fcpeuro.com.
Are you gonna eat that?
I did Redline in trans and Motul in rear-end, and made shifting a bit cleaner/better, but more to be on the safe side and switched at 100k miles.
Here's the RedLine web page to check oil type.
https://www.redlineoil.com/find-products-for-my-vehicle
BMW Gurus:
Does anyone use Mobil 1 fluids for manual transmissions and diffs???
Thank you in advance
Mike
