Results 1 to 15 of 15
Thread: 2000 e39 bmw 528i found metal filings in Antifreeze when flushing aft water pump fail
    San francisco, Ca
    2000 528i
    After finding water pump leaking. I decided to flush coolant system. When draining radiator (5 yrs old) I found some metal filings. Not sure if aluminum or steel? Didn't think to try magnet on them. So I did a flush until I saw no more filings. The Radiator is a Behr model with aluminum fins and plastic sides. Any thoughts? thx
    Nov 2018
    La Habra, CA
    2002 525i
    Did the failed water pump have a plastic or metal impeller?
    San francisco, Ca
    2000 528i
    The old water pump had a steel impeller and looks like its intact. I didn't notice before I removed the old water pump if it was maybe rubbing on the inside of the housing? I wish I would've done a magnet test on the filings. I'm hoping that it's just some filings from the radiator? I don't really see it coming from anything else? Any other thoughts?
    thanks
    Quote Originally Posted by E39 Newbie View Post
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    How old is the radiator ? and the water pump ?? I'd guess those metal shavings are coming from the water-pump steel impeller.
    San francisco, Ca
    2000 528i
    Water pump I think is 9 years and the radiator is 10. There have been on signs of leakage until the water pump starting leaking the other day. They both have about 47K on them.
    Quote Originally Posted by Chedley View Post
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    I've heard that the metal impeller can hit the engine if the bearing is starting to go bad. Check if there are marks of it rubbing.
    Jan 2016
    Ca
    2001 525it
    The metal impeller could dig into cylinder #1 bore if the water pump bearing was loose and caused it to wiggle a lot when you remove the pump you can see the bore right there, hence the plastic impeller, people say plastic impeller is stupid well there's your reason why they use it
    San francisco, Ca
    2000 528i
    It doesn't seem that there's any play in the Water pump shaft. But who knows at high speed. I wish I new about the plastic impeller, I would have ordered it instead of metal one that's coming today? Oh well only planing on keeping car another two years. Thanks again for all the feedback.
    Quote Originally Posted by jclausen View Post
    Nov 2018
    La Habra, CA
    2002 525i
    There are two schools of thought on the plastic impeller. My BMW mechanic friend prefers the metal ones, saying they last longer. You'll find the subject debated on various boards.
    From my somewhat limited experience, 10 years is way past time to replace both items. It's not just the mileage, it's the age.
    Jan 2015
    Shreveport Louisiana
    just an fyi, the impellers were plastic on the early E39's, which had a failure problem. the plastic was done away with, impellers are now composite and more reliable. ive been using HEPU water pumps with stainless impeller for quite a while now with no issues. HEPU is the OEM for volvo.
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Did someone previously load up the system with stop leak?
    It is silver metallic, and looks like metal.
    San francisco, Ca
    2000 528i
    no stop leak
    Quote Originally Posted by wagons ho View Post
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    I use Hepu pumps too, and cut a thicker silicone gasket on the V8 to prevent chances of the impeller rubbing. On the I6 haven't replaced it yet, leaning towards HEPU too.
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    Who cares what the stuff is. Time for a total cooling system refresh or this e39 will be in the boneyard soon.
    San francisco, Ca
    2000 528i
    All together again. Hopefully holds together for a few more years.
    Thanks for all the feedback
    Quote Originally Posted by crazy4trains View Post
  1. E39 1998 E39 BMW 528i Part Out - $2000 Norwalk, CT
    By tre in forum Whole Parts Cars
    Last Post: 04-18-2019, 11:58 PM
  2. E39 1997 e39 BMW 528i AT new 45k engine
    By dhruway in forum 5 series & 6 series
    Last Post: 10-07-2012, 10:34 AM
  3. E39 1997 e39 BMW 528i AT new 45k engine (157k on car)
    Last Post: 09-27-2012, 10:37 AM
  4. Replies: 12
    Last Post: 07-28-2011, 03:24 AM
  5. E39 NEW Koni FSD with Eibach Pro Kit for e39 BMW 528i/540i PLUS MORE
    By kakorat in forum Suspensions, Springs & Shocks
    Last Post: 03-19-2008, 11:28 PM
