Results 1 to 5 of 5
Thread: Is my piston ok after bent valve?
    Apr 2019
    Littleton
    BMW e36 325ic
    So awhile back I was driving my 1994 E36 325i convertible and long story short I missed a gear and over-reved it. It started misfiring and with a compression test it showed cylinders one through five had 150PSI as they should. Number six however had 75 indicating bent intake and exhaust valves. I pulled everything apart including the head and I can't tell how badly its bent or if the cylinder itself is still ok. Was wondering If anyone could help me determine this? It is my first time going into an engine this far and I frankly don't know what I'm looking
    IMG_6177.JPG.pdf
    Last edited by shogun; 04-21-2019 at 05:56 PM. Reason: trying to fix the not working pics
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E36 forum from Forum Software Questions & Suggestions. Try to upload the pics on a free server and posts the links, I try to fix your pics, but no success.
    Jun 2010
    NY
    1997 328i
    Images aren't showing, use another host.
    NW suburban Chicago
    hiss by my window
    Can't see images but it's doubtful the piston is ruined. Typically they'll have "witness marks" from the event and smoothing any sharp raised edges that would promote detonation is all that needs to be done. Again, can't see your photos so............
    Nov 2011
    Loiusiana
    1998 BMW E36
    Quote Originally Posted by ross1 View Post
    Yeah it's hard to really say without seeing the photos, but if it was a quick over rev and you didn't bang on it for long I'd say just your valves are ruined but likely didn't cause detrimental damage to the piston head.
  1. Bad timing/bent valves after S52 cam swap in M52?
    By JordanE36 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-22-2018, 02:37 PM
  2. Bent valves after broken timing belt?
    By 66TriumphTr4a in forum 1983 - 1991 (E30)
    Last Post: 11-03-2006, 09:36 PM
  3. Potentially bent valve after VIR this weekend; questions
    By Neon01 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-28-2006, 10:46 AM
  4. # 3 Missfire- BMW says bent valve
    By ultim3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-23-2002, 03:35 PM
  5. what to expect from bent valve?
    By bmwada2ud in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-01-2002, 10:24 AM
