Results 1 to 7 of 7
Thread: Key Fob Issue (rare stuff)
    Oct 2012
    Miami, FL
    01 325i
    Question Key Fob Issue (rare stuff)
    Hi, i recently purchase a 2007 X3 with 115000 miles on it, but key fob never worked, we have to lock and unlock inserting the key in.
    so i bought a new battery thinking this was the problem, and when i open the fob i saw battery - terminal was broken, i soldered it and soldered back into the fob, checked the voltage with a multi-miter and its 3V constant, so i reprogram the fob to the car:
    open the IS 1 position, close, hold the unlock and hit the lock 3 times, locks inside the car went down and up.
    now my problem its the following:
    car will unlock from the fob but doesn't lock, i check that all the buttons on the fob are working (otherwise couldn't program it either) central locking works, unlock and lock, no fuse its wrong, i program the key around 3 times, but still truck opens, car unlock, but doesn't lock.
    anyone with an opinion i can follow or a diagnostic for this?
    thanks
    Mar 2019
    ATLANTA GA
    456 X3s
    Quote Originally Posted by bimmer210 View Post
    thanks
    If I'm reading this right...a day or so ago I tried the same thing.
    Battery had a broken terminal....I tried to glue the broken terminal/prong. Fob didn't work! Ordered new battery installed/ soldiered battery into place...fob now works fine!
    Lesson: always start with installing new Undamaged battery.
    Sometimes spit and glue just will not work
    Sent from my SM-J727T using Tapatalk
    Oct 2012
    Miami, FL
    01 325i
    got it, but i solder the battery i didnt glue, and i measure the terminals on the other side and they are fine, my key work now fine its just that it doesnt want to lock, but i will order a new battery because the one i ordered prior have terminal on both ends and the one i use has it close to each other. but thanks for the reply.
    Mar 2019
    ATLANTA GA
    456 X3s
    yeah terminals are not straight across from one another but, at 90° angle...you got it!
    Oct 2012
    Miami, FL
    01 325i
    my wife just told me FOB stopped working again, so i already ordered a new batt see if that solve the issue. since i have the N54 engine i know that bmw scanner 1.4 wont do trick here, but will it work with other computers?
    Mar 2019
    ATLANTA GA
    456 X3s
    Didn't get the question...
    Oct 2012
    Miami, FL
    01 325i
    if i put a bmw scanner 1.4 on that car do i still be able to see and program other modules? like ZKE, LCM, IKE? i will try today btw
  1. Help please! Key Fob Issue!?
    By Praetorin in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-16-2008, 08:24 PM
  2. Key FOB issues
    By GXPVince in forum 1995 - 2001 (E38)
    Last Post: 10-08-2008, 05:15 PM
  3. Brake light and key fob issues
    By st8uned in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-29-2008, 10:24 PM
  4. e39 key fob issues
    By mxa16 in forum 1996 - 2003 (E39)
    Last Post: 03-05-2008, 04:28 PM
  5. Remote Key Fob Issue
    By dave6 in forum 1999 - 2006 (E46)
    Last Post: 11-30-2006, 04:17 PM
