Results 1 to 8 of 8
Thread: Door wiring 92 coupe
    Apr 2019
    Norway
    94 325is coupe
    hi, the wiring in my doors have been cut by previous owner, so am looking to replace it. can I use whatever (coupe, sedan, any year) as long as its from a e36?
    Oct 2003
    Seattle
    99 M3
    Use caution, mid MY 1996 (and later) cars got door side airbags.
    And stay with Coupe or Sedan as the lengths will be different.
    Apr 2019
    Norway
    94 325is coupe
    Thanks. So if i understand correct, both sedan and coupe wiring uptil 1996 will be direct fit?🙂
    Oct 2003
    Seattle
    99 M3
    Coupe and Sedan wiring is going to be different due to the length of the doors being different, coupes are longer @ ~48 1/2, with Sedans @ ~42 1/2
    Apr 2019
    Norway
    94 325is coupe
    Ok i see, thanks 🙂
    Apr 2019
    Norway
    94 325is coupe
    did manage to find a few (ex. 94-95) wire looms, but it seem the connector for the window "engine" is much smaller than the one for 92-93 cars (my car).
    is there a way to fit it for my car regardless? maybe change the connector? the window engine on my car has 2 points for connectors, one small and one big.
    Oct 2003
    Seattle
    99 M3
    Use the last seven of your VIN in www.realoem.com.
    Poke around the electrical section, perhaps you can find the connector and splice it in.
    Alternatively look for part outs on your local Craigslist and FB.
    Apr 2019
    Norway
    94 325is coupe
    Yeah, most likely i will have to splice something, the harness for my car is hard to find. Believe they produced it for one year or so.
  1. E36 WTB 92-93 coupe window motors and door wire harnesses
    By KREATURE in forum Exterior Lighting & Body Parts
    Last Post: 09-09-2013, 09:03 AM
  2. E36 WTB: Black Coupe Front and Rear Door Panels (92 325is)
    By Doesnt Matter in forum BMW Parts Wanted
    Last Post: 06-22-2011, 07:30 PM
  3. Door wiring - putting a 95 door on a 92
    By jeffreylane in forum 1991 - 1999 (E36)
    Last Post: 03-14-2010, 02:57 PM
  4. Need 1992 325is coupe door wiring harness
    By E36Death in forum Exterior Lighting & Body Parts
    Last Post: 09-05-2009, 11:03 PM
  5. Coupe / Vert: Door Wiring Harness Replacement
    By fullswing in forum 1991 - 1999 (E36)
    Last Post: 09-29-2005, 10:46 PM
