RM European Auto Parts
Results 1 to 9 of 9
Thread: A/C compressor help
    Mar 2019
    Johnstown, Pa, U.S.A
    2000 bmw 328i
    A/C compressor help
    Hi guys. This is my first post here. I've scoured the interwebs trying to find a solution to my problem but have had no luck. The a/c compressor clutch doesn't engage. It does engage if I jump it but cold air still does not come out of the vents. The only clue I can think of is that the radiator fan doesn't turn on either. Could that be part of the problem? I've read somewhere that the fan has to be on for the a/c to work.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check fuses 28, 62 and 63. Those are the ac fuses. Use a digital volt meter to properly check them. Place a meter lead into the openings on the top of each fuse. Any voltage reading other than 0 volts DC means fuse is bad. If a new fuse blows you have an electrical issue.
    If it’s not a fuse, take your car to a professional automotive air conditioning shop. Likely the refrigerant (R134a) is gone. Do not apply power to the electric clutch as this might damage the compressor. Do not attempt to fix the problem by dumping R134a into the system. Modern ac systems require a precise amounts of refrigerant and compressor oil. Over-or under-filling the system will cause problems.
    The shop needs to:
    - evacuate any remaining refrigerant
    - vacuum test the system (usually for 30 minutes)
    - add the precise amount of refrigerant
    - add fresh compressor oil.
    Now, if the ac went out all of a sudden you need to have the shop add an ultra violet dye to the refrigerant. That way when the ac stops again the shop can use a uv light to find the leak.
    The E46 ac system is pretty robust. I’ve heard/read about very few issues with this system.
    Now, the issue could be related to the automatic climate control module (IHKA in BMWspeak) that sits in the dash. If the ac shop says the refrigerant level is ok then the next step is to scan the car with BMW-specific software. Find a reputable indie shop that specializes in bimmers at www.bimrs.org.
    Mar 2019
    2000 bmw 328i
    So I take the fuse out and put the multimeter where the fuse was?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    No, you read that wrong. Typically on top of most blade fuses, there will be a test spot at the top looking like a "-" dash. That is where you would place the leads at, one on each end.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    NW suburban Chicago
    hiss by my window
    There are low and high limit switches that will prevent the compressor from running if pressure (charge) is too low or too high. Given that you are able to run the compressor and there is no cooling chances are good you have low refrigerant charge.
    I'd be checking pressures before chasing any electrical red herrings.
    Right. Have it properly evacuated, and recharged before doing anything else.
    E46 evaporator leaks are super common.
    Jan 2016
    Ca
    2001 525it
    Exactly
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Seems that BMW has a problem with evaps and expansion valves. I went through 2 evaps and 2 expansion valves in 15 years of ownership with my 1985 325e. However, the ac in my 2001 330Ci still works fine according to the guy I sold it to.
    dworthy's Avatar
    Nov 2010
    The evaporators get clogged with junk, and that starts to eat the aluminum, thus a leak. I had to replace the original in the E-36 when I first got it to get the A/C working again. I think removing the bumper to clean it every couple of years can help, but I don't think the average person would do this.
    Darin
    Current:
    Past:
    M-Flight Member
  1. 1996 328is a/c compressor help!
    By talkingtomyself in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-01-2007, 02:21 PM
  2. Compressor Help
    By Jetblack95 in forum 1991 - 1999 (E36)
    Last Post: 07-25-2006, 01:02 PM
  3. Recirculate button for HVAC turns on AC compressor... help?!
    By medik212 in forum 1991 - 1999 (E36)
    Last Post: 04-12-2006, 04:41 AM
  4. ac compressor help
    By laocoholic in forum 1991 - 1999 (E36)
    Last Post: 04-27-2004, 10:11 PM
