Results 1 to 3 of 3
Thread: E36 M3 trans/clutch noise
    Aug 2009
    CA
    E36
    I just did a full transmission/clutch re fresh and its making noise The trans makes noise only with the clutch out but as soon as its pressed in its totally quiet. It sounds like its the TOB but its a brand new Luk one. It also is louder or quieter at times, like if I leave the car in nutural and let the clutch out slow its quiet sometimes. But if I let the clutch out kinda quick it gets louder.
    Anyone have any ideas if it could be anything but the TOB?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    A bad TOB will make noise typically when the clutch is depressed. Now, a TOB can make noise when the clutch is not depressed if it’s either a bad unit, if it’s not seated properly in the clutch release fork or if it’s the wrong TOB. Did you buy the clutch as a kit or did you buy individual parts?
    Aug 2009
    CA
    E36
    I bought individual parts its a f1 stage 3 clutch and LUK TOB. What are the chances the bearing was faulty? or I have heard of the trans input shaft bearing being bad but I'm not sure it would be quiet with the clutch in. The part that gets me is that if the car is not in gear and I let the clutch out very slow it's quiet.
  1. :::: Clutch problems e36 m3 | clunking, spinning noises when engaging ::::
    By rGrissM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-22-2014, 05:38 PM
  2. E36 E36 M3 Fan Clutch
    By jps1995m3 in forum Engines, Performance Parts & Software
    Last Post: 03-30-2011, 06:15 PM
  3. E36 E36 M3 Flywheel / Clutch / Pressure Plate / 2 clutch forks / 2 throw out bearings
    By Volf in forum Drivetrain & Transmission Parts
    Last Post: 02-07-2011, 02:27 PM
  4. E36 E36 M3 Sachs clutch Brand new
    By 99HellrotM in forum Drivetrain & Transmission Parts
    Last Post: 11-01-2010, 01:52 PM
  5. FS E36 M3 NEW clutch & 5 spd getrag trans in Maryland
    By Compactive in forum Middle Atlantic - US
    Last Post: 09-20-2009, 09:53 AM
