Results 1 to 14 of 14
Thread: Blimey, that was close!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    A couple of days ago (after pressure washing the drive) I found a bolt under the car - so I had a good look around the engine and couldn't find any missing ones - I even went through all the last jobs I had done on the car to see if I could find where it came from but no luck.
    The car is my daily drive so I drove to work as usual with nothing unusual and just guessed that I had blasted the bolt across the drive when pressure washing. The next morning I fired it up and reversed out of the drive and I noticed another bolt sitting there - exactly the same as the last one.
    From Realoem I found that an M8 x 16 bolt is only used in a couple of places - and one of them being the Harmonic Balancer (Vibration damper) so I guessed I best have a look at it - and this is what I found:
    The four bolts that seemed to be OK were all very loose - that damper was ready to fly off any second - and at 5500 RPM it would have done a lot of damage!
    So, how's that for luck, the car has covered over 100 miles this week and both bolts that came off ended up in the drive - what's the chances of that!
    P.S. I've had the car for eight years or so and have never removed those bolts, my only guess is that the water pump was replaced before I bought it.....
    My BMW Repair YouTube Channel
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Go buy yourself a lottery ticket!
    Sent from my SM-G965U using Tapatalk
    Jan 2012
    Upstate South Carolina
    1996 840Ci / 2007 B7
    Very fortunate! I've had those bolts off a bazillion times in the last few years. As long as I've torqued them to spec, I've never seen any back out. Vibration issues?
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    Timm...you are one lucky guy!!
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Timm, thanks for the heads up, how many miles on your 840?
    While you are at it, check your oil pump bolts, they are also known to come loose on the M60/62, I have seen as many as 4 bolts and a nut in the lower sump. 3 from the pump body, the other 2 were attachment fasteners, only one was holding to the engine. Here is a photo from a car in Arizona that we inspected recently with 160k miles on it.
    This is on another car with 120 on it:
    Both cars are M60 engines.
    Regards,
    Brian
    Cave Creek, AZ
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    167,000 Miles or so on the E31, I wouldn't be surprised if half a dozen bits and bobs are about to fall off - but hopefully in a less spectacular way than the harmonic balancer would have departed the engine bay.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    That's a good mystery. There's literally no reason to take off the harmonic balancer unless it is out of balance or if the lower timing cover has to come off for a timing chain replacement or something. Lady luck smiled on you.
    Brett
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    you are indeed lucky Timm, a few rallys ago i lost the entire piece ( balancer/pulleys/flange) on the E9 M30 engine which has a nut on the crankshaft ( not a bolt as the 850) . Lucky too it smashed against the road ( not the hood) in pieces ... to find later a pulley piece in a flat rear tire.
    I check often many things , but so far never the "Jesus" bolt.... now i do
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by ltbrett View Post
    Brett
    I guess you have never had to replace a water pump yet...
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Quote Originally Posted by TxGR8White View Post
    From what I recall, I don't believe this needs removed for the waterpump - it is doable with it in place.
    Bigger issue is the rubber separating on the balancer itself. Mine has quite a bit of cracking and was removed to send out for repair:
    damperdoctor.com
    What "thumbs up" really means
    Dec 2007
    Dallas, TX
    V8’s have to have the damper removed to change the water pump - just did it on an M60 a couple of weeks ago.
    Mar 2011
    I'm going off 7 years ago. You're right. Balancer comes off but the the J bolt stays.
    Nov 2013
    Whitney, TX
    97 850CI
    Do you always drive at 5500 rpm? I would love to take a ride with you Timm. That sounds like a lot of fun.
    Desecrator of all things Sacred
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    Apparently there is some disagreement about pulling the balancer to replace the water pump. I've done it both ways on an M60. Better access with the balancer removed but it is not necessary.
  1. One touch close sunroof possible? Dealer say's no?
    By Tommy in forum 1992 - 1999 M3 (E36)
    Last Post: 09-04-2002, 09:58 AM
  2. Rear ashtray lid not closing...
    By Andre325i in forum 1991 - 1999 (E36)
    Last Post: 07-12-2001, 12:05 AM
  3. close call
    By XOC in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-26-2001, 05:26 AM
  4. Close call in San Diego
    By jaramill in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-23-2001, 01:30 PM
  5. How close do these colors match the "M" stripe?
    By Bob ///M3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-23-2001, 02:38 PM
