Results 1 to 4 of 4
Thread: battery guys in here please
    Apr 2019
    goose creek sc
    1999 bmw
    hello , car has to be jumped off after sitting a lot for the past few years (new battery 2017). i put a charger on it and while on the charger i am showing 13 volts but when the charger "full charge" i removed the battery and voltage is 10.5 volts. what i can tell after research is possible battery is sulfated? or a dead cell from sitting a lot even when a not so old battery
    thoughts???
    Oldham UK
    '00 330i Sprt '92 525i
    Sounds like the battery has a shorted cell. So 5 are charged fine but there is one that is dead. A lot of 'sealed' batteries just have some very sticky tape placed over the top of the cells. (If you rub your finger or a coin over the tape, it will show up the outline of the cell caps.). If you can remove the cell caps, use a hydrometer to check the SG of the acid in each pot. It should be 1.265. Which is a pretty useful number because a fully charged battery will have very close to 12.65 volts
    Apr 2019
    goose creek sc
    1999 bmw
    thanks for the reply ...yep its dead new one installed and all is well
    cowichan bay, bc, canada
    06 330ci zhp convertible
    when sitting you gotta charge it nearly monthly...
  1. Can I join your guys club? Pretty please?
    By Ben Carufel in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-08-2005, 05:30 PM
  2. Battery drain: wiring issue? Please help an ICE noob.
    By berserkr in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-25-2005, 11:37 AM
  3. Guys in Colorado Please help!
    By Lorgow in forum Great Plains & Rocky Mountains - US
    Last Post: 02-06-2003, 12:06 PM
