Results 1 to 13 of 13
Thread: '95 BMW 318is, Sat For 13 Years, Engine Won't Turn Over.
    Jan 2019
    Orlando, Florida
    1995 BMW 318is M42
    Question '95 BMW 318is, Sat For 13 Years, Engine Won't Turn Over.
    1995 BMW 318is,
    Left sitting in my garage since I was a kid (2006), my dad bought it as a mechanic's special but never got around to fixing it all these 13 years. My dad also can't remember why it wouldn't start.
    Maintenance done: Replaced spark plugs, replaced fuel filter, changed engine oil and filter, filled car with a couple of gallons of gas (car was left sitting with zero gas in it), replaced timing belt, replaced battery, replaced engine coolant, checked all connectors and hoses.
    Confirmed that the fuel rail has sufficient pressure (jumped fuel pump and applied 12v to fuel injector, they all fired just fine), confirmed engine has spark.
    Compression test results: 60, 180, 115, 180 PSI.
    I've tried to make the engine run on starting fluid and it almost turns over and I just end up hearing a big bang followed by smoke coming out of the exhaust. I've been told the engine should turn over with starting fluid but this doesn't happen, I've also been told by friends that all cylinders should be at least 90 PSI. Could that one cylinder be preventing the car from starting? This also leads me to believe the fuel injectors are not firing because the only signs of the engine coming to life are with starting fluid.
    Apr 2017
    NJ
    1995 318ic
    Thats pretty low. If I remember correctly, healthy numbers are around 200 psi for an M42 but dont quote me on it. Its a relatively high compression engine
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Does the fuel pump prime?
    Dec 2018
    Brunswick Georgia
    Bmw E36, Lincoln LS,
    Your correct about psi might be a ews module problem
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Dec 2018
    Brunswick Georgia
    Can remember exactly what ews stops, fuel or spark
    Dec 2018
    Brunswick Georgia
    Also when I bought my 93 it had the same problem turned out the dme relay was slightly corroded
    Jan 2019
    Orlando, Florida
    1995 BMW 318is M42
    Yeah the fuel pump primes, I just really wonder if that 60 psi on one cylinder is enough to make the engine not turn over. Can anyone help confirm this? I'm thinking of trying out a different DME from the junkyard also.
    Jun 2010
    NY
    1997 328i
    Could be the cam sensor, check that first.
    The one low cylinder is not bad enough to prevent the car from starting, i wouldn't worry to much about it. After you get the car running again, use injector cleaner over the next 3 tanks of gas.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Check cam amd crank sensors for proper ohmages. Pull the injectors and make sure they flow useing the diy youtube methods with air pressure or fuel cleaner spray.
    The low compression is probably dry cylinder, pour a couple cap fulls of oil into the cylinder with low compression and let it sit for a few hours before doing another compression test or attempting to start.
    -Oakdizzle
    Jan 2019
    Orlando, Florida
    1995 BMW 318is M42
    Hey guys, I'm back, just started a new job. I'm planning on updating this post frequently and thank you for your responses so far. I'm determined on getting this car running.
    So, I've checked both the cam, and crank sensors and I'm getting proper ohm readings on them (about 530 ohms). The fuel pump is priming also and I replaced all of the injectors too. I checked the power connectors to the injectors and they get 12v when cranking the engine. All of the cylinders are now at above 100 PSI, I just poured engine oil down the spark plug holes. I also took off the valve cover and the camshafts looked pretty clean.
    I decided to replace my red label 282 DME with another 282, and when I tried cranking it, I noticed smoke coming out of the exhaust pipe for the first time. Also I heard signs of life come from the engine similar to when I unsuccessfully tried to turn the engine over with starting fluid but I wasn't able to replicate the engine coming to life upon further cranking. I noted that the exhaust smelled of gasoline. I checked the vin https://www.mdecoder.com/decode/jc17290 and it says it came with an S900A Electonic Immobilizer, so I believe it has EWSI, although that shouldn't be a problem. Any thoughts guys?
    Jan 2019
    Orlando, Florida
    1995 BMW 318is M42
    Lifted up the fuel rail and I just confirmed that I saw all 4 injectors spray fuel out! What could it be at this point? I sprayed the ICV with MAF cleaner and I checked my compression and I'm above 100 on all cylinders. Could the engine still be flooded with gasoline and still have good compression?
    Jun 2010
    NY
    1997 328i
    Look up the values of the sensors one is supposed to be over 1000, one of the books is wrong the values are swapped.
    Jan 2019
    Orlando, Florida
    1995 BMW 318is M42
    Interesting development, I have relinquished the troubleshooting to a mechanic near me, he told me I needed a new crankshaft position sensor for $300 parts and labor (I was shocked because I tested the sensor weeks ago and it came back at 540ohms, which is what it should be). I decided to take the car back and buy the sensor myself. The part should be here in a few days but I decided to take the current sensor out and test it again, it did come back as 550 ohms but it looks like it's been mangled.
  1. CA: For Sale - 95' BMW 318IS..$10k LA/CA
    By SlammedBMW in forum BMW Cars For Sale / Wanted
    Last Post: 11-21-2004, 10:51 AM
  2. CA: For Sale - 95' BMW 318IS..$13k LA/CA
    Last Post: 12-17-2003, 03:43 PM
  3. 95 Bmw 318is 4800$ Bbs- Euro's -
    By 95bmwint in forum BMW Cars For Sale / Wanted
    Last Post: 08-09-2003, 06:37 PM
  4. Fs: Two Oil Filters 92-95 Bmw 318i,318is,318ti
    By stuttgart in forum BMW Parts For Sale
    Last Post: 08-06-2003, 09:48 PM
  5. whats my 95 bmw 318is worth?
    Last Post: 07-02-2003, 09:32 AM
