Results 1 to 3 of 3
Thread: Change in wheel offset
    Mar 2019
    Austin, TX
    2006 Z4, 2001 Z3 2.5
    Hoping someone on here has changed their rims for other BMW rims with the smaller 37ish MM offset vs. the 43 standard rims. I did a search and could not find any threads. There are a TON of 17"x 7 or 8 inch BMW rims available with most having a 37mm offset. Am I thinking about this wrong or would this just push the wheels out less than 1/2 inch ? Seems like it would be a good look and on my 2001 Z3 I know there is room in back for that. Anyone having run a smaller offset please chime in and let me know if I am ok to do this. Thanks all !
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Et 37 on an 8 inch is really close to the strut in the front. I don’t have stock suspension though. May be different with stock.
    7 in might work in the front.
    Back should not be a problem.
    Check out YouTube for how to measure. Will save you the trouble of guessing...
    Nov 2009
    Herndon, VA
    99 z3 2.8L
    I use www.willtheyfit.com plus physical measuring the gaps between the wheels, body, and suspension components. A lot of the wheel specs affect one another in ways that the site makes it easy to compare visually.
  1. Changing wheel offset
    By silversled in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-06-2005, 07:34 PM
  2. Who has changed steering wheel?
    By GSBMW325is in forum 1991 - 1999 (E36)
    Last Post: 08-13-2001, 12:23 AM
  3. Any way to change wheel offset?
    By Harry in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-05-2001, 02:35 PM
  4. wheel offset
    By monterey in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-18-2001, 02:17 PM
  5. Quick wheel offset question... thks
    By TC3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-21-2001, 12:02 AM
