Results 1 to 3 of 3
Thread: Clutch Job E46, Grease Application Points
    West of I-270
    325xiT E46
    Are we supposed to put a bit of grease on the trans input shaft bearing retainer on which the clutch release bearing slides? The bearing itself is mostly plastic, especially where it slides back and forth on the trans input shaft bearing retainer. If so what type of grease?
    Jan 2016
    Ca
    2001 525it
    Yea on the splines, on the end of the input shaft going onto the pilot bearing, on the collar that the throw out bearing slides on, the throw out bearing arm pivot ball, any thing that slides or pivots of course not a ton on the splines since it spins and would throw it off into the new clutch parts. I used redline grease on my bmw BMW bike splines or I have Honda moly grease too.
    Jun 2012
    New Mexico
    2003 328i
    BMW used to recommend Microlube GL261. Honda uses high temp urea grease. You do want to use a suitable product, not just any grease is appropriate.
  1. E46 For Sale: Lightweight Flywheel & clutch - '03+ E46 330 6-speed/SMG, Z4 3.0, '04+ 53
    By scrubed in forum Drivetrain & Transmission Parts
    Last Post: 05-21-2015, 07:44 PM
  2. E46 SMG Shift Actuator and Clutch Kit - E46 M3
    By MisterM in forum Drivetrain & Transmission Parts
    Last Post: 07-14-2012, 11:19 AM
  3. E46 FS: UUC LW Flywheel & clutch - 03+ E46 330 6spd/SMG, Z4 3.0, 04+ 530i
    By Frostvr4 in forum Drivetrain & Transmission Parts
    Last Post: 10-15-2010, 07:44 PM
  4. how much for a clutch job?
    By RichP in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-14-2001, 11:07 PM
  5. how much for a clutch job?
    By RichP in forum 1991 - 1999 (E36)
    Last Post: 11-10-2001, 11:25 AM
