Results 1 to 15 of 15
Thread: 840 driveshaft
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    840 driveshaft
    Hi folks. As you can tell from my avatar I have three pedals. The 6 speed swap has been completed for two or three years. Every part was new or used original BMW except the drive shaft. I had mine cut and balanced. I have since (as of yesterday) replaced my cut and balanced drive shaft with a new OEM shaft and it fit perfectly. This also validates, at least in my mind, that the swap was done correctly. The only difference that I can figure between my swap and an OEM built six speed is the fact that I do not need to depress the clutch to start the car. I think I could have installed that switch as well, but going back to every other stick shift car I have owned there never was a need to depress the clutch in order to start the car. So why start now?
    If anyone is thinking of performing the six speed swap I have your drive shaft in the box and ready to ship.
    The OC, CA
    95 840Ci
    Did you notice any difference between yours and the OEM shaft? How much? Ship to OC?
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
    Oro Valley, AZ - USA
    see my signature
    Shipping to Tucson might be closer! Plus Rick's driveshaft was cut to fit a green 840ci, not a blue one! Lol
    Hey just kidding Mark, since we're all current or former 840 6 speed owners here
    Where did you get your driveshaft Rick? Schmiedmann? That's where I was planning to get one from. But not so sure I can stomach the thought of conversion anymore, with 5 other BMWs to feed, there's just too many other projects!
    The OC, CA
    95 840Ci
    Joe, your zoo doesn't seem to be getting any smaller. But I think 6 speeds were born to be blue!
    Current
    Past
    see my signature
    Haha, Rick might disagree with you there! And yes the zoo is being over'run by greenies!
    BTW the part number is 26101227880, looking for the 1418mm driveshaft. It is unique to the 840i (not Ci, although we don't make that distinction here in the USA market). RealOEM says it was used on some autos too, but not sure what transmissiond those 840s would have.
    Nov 2018
    Sweden
    1994 840ci
    Quote Originally Posted by rjbaren View Post
    I have a eurospec manual 840 -94 ,and I don't need to press the clutchpedal to start the car.
    Jun 2012
    Mundelein, IL
    Well Mr. Davidof, thank you for that bit of information. I guess my 840 is up to date then.
    Jun 2020
    Bay Area
    1994 E31 840ci 2000 Z3 M
    Are you still selling your drive shaft? Im currently in the middle of my swap and I the shop nearby me said they dont think they can lengthen my because the u-joint is bad. I could order another automatic driveshaft but at that point I could order a manual (I think) from germany.
    A question for someone who might know the answer to this: should a reputable shop be able to lengthnen these deiveshafts and replace the u-joint with a servicable u-joint?
    Sent from my SM-G970U using Tapatalk
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    U Joint Replacement
    These are your options on the U-Joint.
    https://www.bimmerforums.com/forum/s...nt-Replacement
    Any shop can make them shorter or longer. Just need the right size shaft after that is is cut and weld
    Jun 2020
    Bay Area
    Thanks rjjablo, I'll look into it.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    www.driveshaftpro.com
    buy a new one...
    you will have to tell them exactly what you need though, as manual 840's did not ship over here
    '91 850i 6sp (mint) (sold)
    Jun 2020
    Bay Area
    Quote Originally Posted by cartoonz View Post
    buy a new one...
    Hey cartoonz, do you have any recommendations for places in the bay area? Right now I'm working with South Bay driveline.
    Jun 2020
    Bay Area
    Spoke to the owner of the driveshaft shop, he's been doing this for 35 years so I have confidence in his work. Now he said that I can find a driveshaft to use as a donor from a 7 series, but since the drivetrain is shared with a 5 series as well, can I use either? And would it matter if its a e34/e39 540 or a e32/e38 740 or 750?
    Sep 2008
    Santa Barbara
    DiveshaftPro is part of a Nationwide operation... ask them if there is a Bay Area affilliate, or just let them ship it - they ship Nationwide too.
    Reason i suggest them is that:
    A: A Brand New driveshaft from them is only about ~$600+/- > a "rebuild/modify" will be more.
    B: The new ones from them have SERVICEABLE U-Joints (Spicer), factory does not.
    C: Betcha they get it to you faster
    I've bought 1/2 dozen driveshafts from these guys and they have always been amazing.
    Jun 2020
    Bay Area
    Hey Cartoonz, thanks for the solid input, I like that it can be repairable. What length should I give them when I call? I measured and found that the front half shaft should be 6 inches longer. If you squish all the ends, then it needs 6 1/8 inches. If you stretch the shaft, then it needs 5 7/8 inches. This is all movement from the cv joint towards the differential, so at rest (center) it needs 6 inches from the back of the transmission to the guibo on the driveshaft.
  1. 840 differential and driveshaft
    By JTM850 in forum 8 Series (E31)
    Last Post: 12-30-2016, 07:20 AM
  2. E31 WTB 840 driveshaft for manual tranny
    By moto4us in forum Parts for Sale
    Last Post: 02-07-2012, 10:59 PM
  3. E31 840 (A/T) Driveshaft NOS
    By gspdbill in forum Drivetrain & Transmission Parts
    Last Post: 10-07-2011, 01:48 PM
  4. WTB 840 Driveshaft auto
    By sctttoth in forum Parts for Sale
    Last Post: 03-28-2011, 11:19 AM
  5. FS: 96-97 840 (e31) driveshaft (new)
    Last Post: 10-09-2007, 09:37 AM
